Old 09-27-2009, 07:18 AM   #1 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Stiffener bar for soft front aero deflector
Installed aluminum stiffener bar for aero deflector that's at rear of the front bumper cover. This is the one that flops around a bit, has a formed notch for the exhaust downpipe. Attached with alum. pop rivets. Stiffener is on top side.
I used a bit of aluminum angle stock that was originally for flooring installation. Is like angle iron except the raised side of the angle is only about 3/16 inch, not equal to the width of the other 'leg' of the stock.
Watch out for bracket at lower corner of radiator, drivers side - the bar was hitting it so I added some foam pipe insulation for padding held in place with duct tape. Would have been better to grind away a bit of the new bar's material before riveting into place.
Coast long and prosper.
I think its time to start my aero journey! pumafeet10 Aerodynamics 17 09-10-2009 01:09 AM
Civic grill block, front undertray, tire deflectors daqcivic Aerodynamics 24 05-13-2009 03:52 AM
Aero deflector Kururu Aerodynamics 7 09-28-2008 10:24 PM
Aero Front End Possibility? Coyote X Aerodynamics 12 06-07-2008 12:43 AM
