07-30-2008, 09:17 PM
Averages seem off
I keep my own fuel log separate from the one on ecomodder. the average i calculate in my excel file is lower than the one in my log here. IDK what the difference is, but all my entries are the same. I attached my excel file maybe check the formulas? i've checked mine and i cant find the problem
(I use the latest version of office, idk what the "dumbed down" .xls file will look like  )
07-30-2008, 09:22 PM
To what decimal do you take your excel file?
Default is 2 decimal, so it rounds,,, highlight all the cells and properties, bring it to 10 spaces if this is the problem.... for the sheet I was keeping, I had to do this to get accurate "per mile" values
07-30-2008, 09:25 PM
It looks like you're actually averaging your tank fuel economy in your spreadsheet, whereas the garage here is technically a cumulative value, not an average (ie. it sums distance traveled and divides by the sum of fuel consumed).
07-30-2008, 09:29 PM
Mr. Blue Tape
I did what Noel suggested (though not to 10 places) on my own spreadsheet to account for the inaccuracies inherent with rounding off.
My 5 pillars of fuel efficiency:- driving style
- aerodynamics
- tires
- weight reduction
- engine maintenance
07-30-2008, 09:45 PM
10 decimal places doesn't change anything significantly
my spreadsheet says my average is 33.77
ecomodder log says 34.26
sum (total miles/total gallons) = 32.27 in excel.
difference in the ecomodder avg and the sum avg from excel is like 9%... relatively big
07-30-2008, 09:57 PM
Your spreadsheet entry for 14/05/08 has fuel volume entered, but no distance value. It's throwing off the results. Omit that value from the comparison and things line up.
07-30-2008, 09:59 PM
  touche
07-30-2008, 10:01 PM
Mr. Blue Tape
ah, beat me to it.
- aerodynamics
- tires
- weight reduction
07-31-2008, 01:12 PM
#9 (permalink)
Now if only I could spot my own mistakes...
07-31-2008, 01:37 PM
#10 (permalink)
Pokémoderator
Noel -
When you say 2 decimal, can you be more specific? It sounds (to me) like you are talking about the display format. If you mean the display format, I thought that rounding did not apply to the actual calculation.
CarloSW2
