Old 06-29-2008, 08:39 AM   #21 (permalink)
Yes, it's there on a plane for carb icing - but they can also go to higher altitudes to get less dense air into the engine and less wind resistance (which is standard practice).
They also have a manual control that leans the mixture and some planes have variable speed props which would be equivalent to a continuously variable transmission (CVT). All of this allows you to operate the engine at max BSFC.
PP-SEL/SES.
Old 06-29-2008, 09:16 AM   #22 (permalink)
I have owned some cars that were very prone to carb icing which manifests itself as lowering tickover as mixture gets over rich and eventually as the carb fills with ice the engine stops.I found the worst conditions for this were a temp just above freezing and damp foggy weather.Perhaps it was my background in aviation that made me experiment with carb heat and mixture controls from within my older cars. I used to have a 282 mile round trip comute and constant adjustment of mixture etc saved a bit of gas and helped break the boredom.
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
Warm air intake? how about warm fuel? ebacherville EcoModding Central 30 03-08-2010 09:37 PM
