Old 09-24-2012, 11:12 PM   #1 (permalink)
TBA - '07 Honda Fit
Check engine light blinking while EOC
Title basically says it all, but here's some history...
Engine was jerking and threw an error code about 6 months ago.
Error code called for getting the CKP (crankshaft position) sensor replaced.
Got sensor replaced.
Getting 35mpg in the city with a 1.5L(manual) honda fit. Was getting 45 mpg in the city.
Check engine light blinks during EOC sometimes. EOC is without a killswitch.
Any ideas?
Old 09-24-2012, 11:48 PM   #2 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
Do you know the code is that is causing the check engine light? If you don't have a code reader there is probably some "key dance" to tell you, For example with my Neon, with the car off I cycle the key to "on" without starting the car, and back to off three times, then on the last time the digital odometer will read out the codes. Your Honda is probably a different set of steps, but likely still a way to do it.
Old 09-25-2012, 09:20 AM   #3 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
So is the CEL doing anything differently that if you come to a stop, key off, and key back on? On many vehicles, CEL blinking, etc is part of the initilization procedure.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 09-25-2012, 10:50 AM   #4 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
autozone will pull your codes for free, likely the other parts places too.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 09-25-2012, 11:57 AM   #5 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
Check the service connector to see if the jumper is still installed. Many Hondas have a plug near the computer(ECM) that when jumpered will flash the Malfunction idicator lamp(CEL) to indicate the malfunction code.
Old 09-25-2012, 12:18 PM   #6 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Blinking CEL is usually signaling a misfire.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 09-26-2012, 09:20 AM   #7 (permalink)
I checked mine out. When I EOC and key off/key on the CEL
1) initally comes on steady for a few seconds.
2) then blinks 10 times
3) then goes steady again until restarting
4) then goes off after the engine starts
I also checked if I just do this with the truck stopped. The same exact thing happens. I think it's perfectly normal.
Diesel Dave
