Old 02-11-2009, 12:51 PM   #1 (permalink)
grille mod
I have a rather flat, non descript grille block now on my '06 Dakota. My plan is to build a new block that will extend to the front bumper following the lines of the down sloping hood.
My question, to all of you aero gurus out there is this: On the horizontal plane, do I use the arc that would extend to the outside edge of the vehicle, or the arc that would end at the inside edge of the headlights?
I know the best would be to totally redesign the front end into a smooth rounded hemishere, but I'm not quite to that level yet.
So, waddaya think?
Old 02-14-2009, 02:26 AM   #2 (permalink)
The arc should go to the outer edge of the vehicle, and blend smoothly into the side
Testing the IAT mod tasdrouille General Efficiency Discussion 6 09-27-2009 04:09 PM
Temperature controlled grille block Piwoslaw Aerodynamics 19 11-09-2008 10:24 PM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 10:19 PM
grille blockers... malibuguy Aerodynamics 24 06-25-2008 01:38 AM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 10:14 AM
