Old 07-27-2011, 11:44 PM   #1 (permalink)
Learning quick
Good Altima - '06 Nissa Altima 2.5s
Smile Chevrolet Cruze Eco Question???
So If I buy thing Cruze Eco 6 speed manual it has a 1.4 liter turbo. Can I engine off coast this kind of vehicle without the turbo exploding? Or hurting the engine?
What do you guys think?
Old 07-28-2011, 12:32 AM   #2 (permalink)
...beats walking...
...engine OFF coasting is not a good idea (especially at high speeds) because the turbocharger (which is physically mounted *in* the exhaust manifold) is cooled (coolant) and oiled (oil) by the same coolant and oil that services the rest of the engine.
...if the engine's OFF, so are the cooling and oiling of the turbo, which is VERY co$tly to replace.
...yes, I have a Cruze 1.4LT, an LTZ model, not an Eco, however.
The Following User Says Thank You to gone-ot For This Useful Post:
Cd (07-28-2011)
Old 07-28-2011, 12:55 AM   #3 (permalink)
Why would you want to?
Old 07-28-2011, 07:53 AM   #4 (permalink)
As Old Tele man says its not good for the turbo. However, you could work around this by using an electric oil pump. You'd need some nifty way of controlling it as well.
Old 07-28-2011, 10:53 AM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Doomz78, check out this thread on EO(ff)C-ing a turbo'ed car. It was meant for turbodiesels, but the same applies to gassers. The bottom line is that you can kill your turbo'd engine, but you should coast in neutral first for a few seconds to allow it to cool down. This pretty much limits your EO(ff)C to loooong coasts, but even then it may still be worth it.
For example, if I'm driving in rolling hills then I try to have 2-4 engine on coasts between engine offing to make sure there isn't too much (thermal) stress. I don't kill the engine if the coast will be less than 500 meters, unless I'm coasting to a red light. On the other hand, it would have been a sin to keep my engine on during 5-6km coasts in the Austrian Alps, ah...
Old 07-28-2011, 12:14 PM   #6 (permalink)
...beats walking...
...unfortunately, there's a BIG difference between a turbocharger bolted onto an exhaust manifold (most other cars and trucks) and the Cruze which (literally!) has it's small turbocharge actually bolted *into* its exhaust manifold (for both turbo "lag" reduction as well as quicker catalytic converter "lite-off").
...if the OP hasn't read-up on the 1.4LT engine in his Cruze, he might consider visiting some of the Cruze forums, such as CruzeForumz.com and CruzeTalk.com, etc.
Old 07-28-2011, 12:35 PM   #7 (permalink)
Just let it cost in neutral instead of turning it off. It will save some wear and tear on your turbo and starting motor.
Old 07-28-2011, 06:24 PM   #8 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Can we assume none of the cautions are applicable if you haven't spooled the turbo up within 30 seconds of turning the engine off?
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 07-28-2011, 06:47 PM   #9 (permalink)
...beats walking...
...how "slow" are you driving? it's active between 1850-4900 rpm.
Old 07-28-2011, 07:16 PM   #10 (permalink)
Pishtaco
SentraSE-R's Avatar
There's no boost gauge? There's a big difference between cruising at 2000 rpm and boosting at 2000 rpm. The turbo only spools a fraction of the time you're in that rpm range, right?
Darrell
