Old 06-23-2012, 10:56 AM   #1 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Testing aeroshell/boat tail For the Dodge
Later today, I am starting a testing aeroshell with integrated boat tail for my truck. No scangauge, I drive it few miles a year, so i am cutting right to the chase. I call it A-M-A testing
I am picking up the template at station 10, a point with 3.5° slope. I figure that will get me down faster, and is not a huge departure from <Shatner voice> the ...beauty , that is....the, template </Shatner voice>.
Length is still not a concrete number. It is somewhere around a total length of 12'.
I welded up my headache rack yesterday, and I will hinge this whole thing off it IF/when I build the permanent one. this one will probably be fixed for testing.
I have some nice big sheets of virgin cardboard to skin it with. A ton of scrap lumber, fasteners, some old gate hinges, etc.
I can borrow the tail lights and a pigtail for the lights.
Why now? I have a 320 mile 55~60 MPH round trip across the mountains to do Monday/Tuesday, and maybe a 450 mile 70 MPH freeway run in the middle of that, fuel paid. These opportunities just do not fall off the trees.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 3 Users Say Thank You to skyking For This Useful Post:
BamZipPow (06-23-2012), Diesel_Dave (06-25-2012), turbothrush (06-24-2012)
Old 06-23-2012, 11:51 AM   #2 (permalink)
90 day: 19.36 mpg (US)
Fuel paid, no kidding!! Looking forward to it.
Old 06-23-2012, 12:15 PM   #3 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.21 mpg (US)
Photos. We need photos.
Old 06-23-2012, 12:23 PM   #4 (permalink)
skyking's Avatar
Right now, it sits in my noggin. I have to build a linux server first, that is the reason for the trip.
I hope to have some framework constructed today that will be picture worthy.
2003 TDI Beetle
2002 TDI Beetle
The Following User Says Thank You to skyking For This Useful Post:
aerohead (06-23-2012)
Old 06-24-2012, 12:28 AM   #5 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Looking forward to the progress. opcorn:
Old 06-24-2012, 05:56 AM   #6 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
I don't recall your Dodge. If it's covered on another thread, a cross link would be peachy.
Rock on!
Recreation Engineer
Old 06-24-2012, 06:56 AM   #7 (permalink)
Gen II Prianista
Rokeby's Avatar
Skyking,
Will fuel be paid for based on:
a. a pre-established per mile rate, (Ka-ching!)
b. or based on gas pump receipts? (Why bother?)
Old 06-24-2012, 08:07 AM   #8 (permalink)
skyking's Avatar
Rock on!
It is Woody, right there below my avatar.
The only other thread:
http://ecomodder.com/forum/showthrea...sel-21857.html
Skyking,
Based on: the 60 MPH portion is for a job I get paid to do, namely set up a replacement server; the 450 mile 70 MPH part is tentative and more informal
Took me a while to get to the truck. I finished up the rack and need to paint it this morning, did not have hinges, need supplies.
Good news? I have help coming.
2003 TDI Beetle
2002 TDI Beetle
KamperBob (06-25-2012)
Old 06-24-2012, 11:06 PM   #9 (permalink)
skyking's Avatar
Help did not materialize, but I moved the schedule back a day. Design by noggin has morphed several times today. Will return with pics when the skeeters start eating me up
2003 TDI Beetle
2002 TDI Beetle
Old 06-25-2012, 01:44 AM   #10 (permalink)
skyking's Avatar
I wanted to use the template as closely as possible, so I designed a shell with longitudinal ribs. Now to get the shape right
I started by laying a sheet of plywood on the floor and tracing it. There is very little else you can find that is more true and square than a sheet of plywood.
I moved it 4 feet, so I could get a 12' grid drawn.
I moved it a couple more times, ending up with a 6' x 12' grid, on 2' spacing.
I hope to build a tail for the truck and thought I could use the length.
Now I could arrange the sheet of plywood to minimize waste.
Using a printed image of the template, resized to suit my truck, I scaled it to get dimensions at stations, and transfer that onto the sheet. I pulled a tape and also made station lines on the angled plywood.
Now I have marks on the plywood that are 2' apart. I want to draw a smooth curve through these points. I have a fiberglass rod for network wiring, but a 10' stick of 1/2" CPVC pipe will work as well.
I started by clamping the rod at one end over a mark, then bent it across the next and the next, taking time to smooth the curve.
I cut the first one out very carefully with the sabre saw. Since the cut is so close to a rip with the grain, the saw wandered pretty badly.
I got a decent looking curve after a couple of attempts, then used that as a guide. Once again, the sabre saw would not track well.
I ended up setting my cordless circular saw to just barely go through the 3/8" ply, and used it instead.
4 finished curves.
I painted the headache rack with something close off the bomb can shelf.
Installed and bolted in solid.
I clamped a piece of 3/8" ply to the rack, and transfer marked it with a straight edge laid on the cab, and cut it out. It has 1/2" margin for the skin and construction method.
My box lids are one of the challenges. I have to make a door in each side of the shell so I can get into the boxes.
This also makes a big hole in the structure I have to work around.
2003 TDI Beetle
2002 TDI Beetle
The Following 6 Users Say Thank You to skyking For This Useful Post:
BamZipPow (06-26-2012), Diesel_Dave (06-25-2012), KamperBob (06-25-2012), slowmover (07-01-2012), t vago (06-25-2012), turbothrush (06-25-2012)
