Old 06-27-2008, 08:32 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
VX shift light wiring?
How's the shift light wiring on the VX done? Looking to hook it up on the CRX, but don't know where to get started.
Old 06-27-2008, 08:54 PM   #2 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 honda civic Hx
Last 3: 58.02 mpg (US)
I believe there is a module on the back of the instrument cluster that plugs in and provides a shift light. A buddy of mine installed a shift light into his hf crx and i'll get some exact details on what was done.
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 06-27-2008, 09:06 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Hmm, I was assuming there was some sort of ecu output for it...
Old 06-27-2008, 09:52 PM   #4 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Honda Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 Infiniti j30
90 day: 22.74 mpg (US)
I think you assume correct. I would assume its just an output that you can place a bulb inline with and run the other side to ground. If you don't get an answer here, a shop manual for the VX should tell you what wire it is off the ECU and possibly what voltage output it is. I do have access to one at work, so if I remember tomorrow, I'll look it up.
Old 06-27-2008, 09:58 PM   #5 (permalink)
Dartmouth 2010
SVOboy's Avatar
I'm planning on just using one of the spare light on my integra cluster (like abs), so I just need to find the correct wire...
Old 07-03-2008, 12:33 AM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
Bump in case anyone knows offhand. I have an idea, but that's it.
Idea for government: Traffic Light Timers newtonsfirstlaw General Efficiency Discussion 29 03-10-2012 11:33 AM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 02:52 PM
Technique quandary: gliding toward a stale green light - to pulse or not to pulse? MetroMPG Hypermiling / EcoDriver's Ed 27 04-15-2010 12:41 AM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
