Old 03-20-2009, 01:22 AM   #1 (permalink)
Is it more efficient to tax the stock alternator, or upgrade?
First off, *flame shield on* I know that electrical loads should be minimized, but I have a burning question: would it be better to tax my stock 80amp alternator or upgrade to a 110amp alt from a larger vehicle (Nissan Quest, in this case.) I know that generally speaking, a higher output alt will cause more parasitic loss, but which you guys think to be greater?
Old 03-20-2009, 01:45 AM   #2 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
I don't know about this efficiency-wise, but beware of "taxing" them anyway. At least on my Honda, the stock alternator will burn up in short order if overtaxed (such as charging a dead battery.) If you're going to "load up" your alternator, best to upgrade it.
Old 03-20-2009, 09:44 AM   #3 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
the higher load will cause the alternator to get hotter and die sooner, so you can either choose to swap the alternator or wait until it fails and hope that you can get home.
Old 03-20-2009, 10:38 AM   #4 (permalink)
Wildfire - '96 Ford Bronco XL
90 day: 14.88 mpg (US)
Blackford - '96 Ford Bronco XLT
90 day: 20.26 mpg (US)
Y2k - '00 Honda Insight
Gen-1 Insights
90 day: 73.98 mpg (US)
Redford V10 - '01 Ford F250 Lariat
90 day: 15.64 mpg (US)
FireFly - '00 Honda Insight DX
90 day: 69.43 mpg (US)
LittleRed - '00 Honda Insight
Keep the stock. The cost of upgrading outweighs the very minimal (if any) efficiency of an upgraded alternator. You'll still pull the same amps. I'd keep the stock til it fails. Cooks choice. Try the upgrade if the alternator is free.
Old 03-20-2009, 12:20 PM   #5 (permalink)
When an alternator is not being asked for power, the only difference between a bigger one and a smaller one is the rotational weight of the rotor and basic rolling resistance of the bearings.
A larger alternator will have larger gauge windings, which will have inherently lower internal resistance at a given output, which will mean slightly more energy efficiency on that side of things - probably enough to balance out the "loss" imposed by its heavier rotating mass.
So... no meaningful reason NOT to do the upgrade, apart from expense if that's a deterrent for you.
Old 03-20-2009, 01:24 PM   #6 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
It would depend on the efficiency curve of your alternator and the one your considering upgrading too. A larger alternator might have a larger coil current and thus more parasitic drag on the engine. Then again the increased heat on your stock alternator might increase copper losses and drop its efficiency.
alternator, efficient, load
Looking for a fuel efficient solution. I've got a few ideas. CuriousOne EcoModding Central 41 03-28-2009 02:46 PM
For the 96% efficient types..... suspectnumber961 EcoModding Central 20 02-26-2009 07:12 PM
Even With Cheap Gas, We Still Want Fuel Efficient Vehicles SVOboy EcoModder Blog Discussion 3 02-23-2009 02:56 AM
Chevy Volt and GM Get Big Boost From $700B Bailout Vote Today Matt Herring EcoModding Central 15 10-09-2008 04:20 AM
Big Surprise: Fuel efficient cars are holding their value better than other cars SVOboy EcoModder Blog Discussion 2 09-19-2008 08:52 AM
