Old 08-22-2009, 02:26 AM   #1 (permalink)
The Move - '99 Daihatsu Move Aero Down Custom XX
90 day: 29.89 mpg (US)
Send a message via AIM to Dust
Choosing a wideband
Several people here talk about running a wideband sensor, but I still have some questions. Some have mentioned that a wideband can output a narrowband signal. What versions do this? Also, which sensor should I look for for the cheapest to replace. Last, I read in here somewhere that you can fib on the signal sent to the computer throuh te wideband, is this tre, and which ones do it?
Old 08-22-2009, 03:47 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I believe it's the controller, not the sensor, that does the outputting as narrowband, etc. Not sure though. Check out PLX's products.
Also, I wouldn't mess around with fibbing about important sensors
Old 08-22-2009, 06:55 AM   #3 (permalink)
If you are handy with a soldering iron, I recommend this.
14Point7.com NAW_OEM
I'm using it with my MS1 kit. Works perfectly every time.
Old 08-22-2009, 03:25 PM   #4 (permalink)
For what it's worth,
The Innovate units, more expensive versions, have programmable analog outputs for the O2 signal, not sure if you can modify a narrowband voltage scale with it though if that's what you're after. I see they have out more affordable controller and gauge kits now also (low 200's) if you just want to monitor.
PLX controllers have been around a while, tried and true for low-mid $200's
NGK units seem sturdy from what I've heard.Techedge pieces are decent as well, an australian company with various models (with the option for an NTK sensor).
Some widebands are notorious, and seemingly destined, for failure so research good before you buy.
Most widebands have a narrowband output along with the wideband output, it really depends what you want to do with it. Some prefer linear output voltage scale controllers as they are easier to set up in tuning software.
I still use a trusty old school plx m300 that has been reliable for 5 years now.
$20 monitoring of air/fuel ratios from std wideband sensor Julian Edgar EcoModding Central 26 09-21-2011 11:59 PM
Help choosing vortex generators Fit Aerodynamics 58 01-08-2011 04:08 AM
Cleaning o2 (wideband in this case) sensors? Daox General Efficiency Discussion 2 05-20-2009 07:42 AM
Choosing a Manual Transmission Fluid for my Mazda Protege 1337 EcoModding Central 5 03-20-2009 12:07 PM
Video: choosing the right size vehicle for the job! (motorcycle tow truck) MetroMPG Motorcycles / Scooters 8 02-14-2008 07:52 PM
