Old 12-16-2012, 04:14 AM   #1 (permalink)
Civic VX - Advance timing & Fuel
I want to advance the timing on my Civic VX to 18 degrees. But, i'm wondering if I will need to use a high octane gasoline to go with the advanced timing?
1992 Civic VX - 45.9mpg *hoping to get this above 50mpg+ soon*
2011 BMW 335D - 34.9mpg mixed putting down 320whp / 510wtq **CMON 35MPG!!!**
2006 EVO IX - 22mpg mixed putting down 400whp / 400wtq
Old 12-16-2012, 08:13 AM   #2 (permalink)
Speedy Gonzales - '11 Ford Fiesta SES
How do you plan on advancing the timing?
What is the timing at normally?
You might get away with it if it's a small advance...under heavy load is when you may cause damage.
Old 12-16-2012, 07:03 PM   #3 (permalink)
Adventurist!
CLaero - '97 Acura CL Premium
90 day: 34.59 mpg (US)
CR-v - '03 Honda CR-V EX
90 day: 26.52 mpg (US)
you're generally safe on hondas to advance timing 4 degrees.
'97 Acura CL 2.2L 5spd
'03 Honda CR-V 2.4L EX 4wd Auto
Old 12-16-2012, 08:31 PM   #4 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I did just 2* and here is my write-up: http://ecomodder.com/forum/showthrea...tml#post244353
What's the stock timing on your VX? Does it have a knock sensor? 2-4* shouldn't hurt anything, and it will help--very modestly--to produce more low end torque, which is useful for us hypermilers since we drive in the under 2000 rpm range most of the time.
Old 12-17-2012, 01:16 AM   #5 (permalink)
I set mine to 16 degrees at base idle.
I was thinking of setting it to 18 degrees. Nothing too crazy.
