Old 04-23-2010, 08:59 AM   #11 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Hey that's awesome! Great place to start; you should see gains pretty quick. I'm hoping to move to them relatively soon with my Elantra. I made some trial ones for my Lumina, and had the same problem as you with sloping sidewalls and bracketing.
Old 04-23-2010, 11:56 AM   #12 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Perhaps what you need is some foam plumbing insulation. It can be carved with a knife and glued or taped on just behind the door to give a new surface with a rounded edge. At the back, just use it as a shim and continue the Coroplast back at a gentle taper.
To remove panels for service, a tape job can be planned so that a single stip of tape does the mounting, and it is easy enough to peel for re-use on the road, or easy replacement. You can buy a lot of tape for the price of a latch plus installation. Using coloured duct tape does wonders for a professional appearance, and plain vinyl top coating tapes are more durable in the weather.
For a neat appearance and a reinforced bottom edge on Coroplast skirts, just slit the inside surface of 3 adjacent flutes, fold over, and use double-sided tape.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
AeroModder (04-23-2010)
Old 04-23-2010, 12:38 PM   #13 (permalink)
I've heard that the type of foam used for pipe insulation can be hot-wired, as is the case with styrofoam. Model airplane (RC) folks reportedly use this stuff, which is impact resistant. Anybody here know about this?
If so, the stuff is much tougher and more weather resistant than styrofoam, and larger diameter pieces can be bought from plumbing supply houses.
Comes in dark grey and tan colors.
You could hot wire foam wedges to fair the air past door posts, etc..
Old 04-23-2010, 02:01 PM   #14 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
Lightweight, cheap, and easy. I might look into that!
In Reason we Trust
Old 04-23-2010, 03:28 PM   #15 (permalink)
No nickname - '17 Chevrolet BoltEV Premiere
Be sure to let us know how the partial rear wheel skirts do. I think they look good and plan to make a more permanent set for my car some day. (Removeable, but out of long lasting material.)
Old 04-23-2010, 03:51 PM   #16 (permalink)
AeroModder's Avatar
Team Ford
Will do. However, I was just inspired by a post here:
http://ecomodder.com/forum/showthrea...html#post44723
I was originally considering using aluminum screen material for an undertray, then I built the coroplast pan. Using the screen between the panels sounds like a good idea.
In Reason we Trust
flow separation:Tiger Woods meets Cinderella,or 5-seconds to a perfect roofline aerohead Aerodynamics 43 10-18-2019 10:22 AM
cleaning the kitchen sink bgd73 The Lounge 5 05-27-2013 03:22 AM
both sides of a metal sheet... bgd73 Off-Topic Tech 3 11-24-2009 06:55 PM
cleaning up oil spills Daox Off-Topic Tech 10 06-02-2009 01:56 PM
Cleaning o2 (wideband in this case) sensors? Daox General Efficiency Discussion 2 05-20-2009 07:42 AM
