04-13-2010, 07:45 PM
Insight 1 Boattail-An Experimental Approach
With all the talk of first gen Insight boattails, which interest me considerabley, the engineer in me begins to emerge. Specifically, I'm beginning to stategize as to the most cost effective and flexible way to get the data on performance. I want a practical boattail, but I don't want to invest a fortune on something which will be proven by the data to be ineffective. Rolling it over mentally, I think I see an approach which will gather the relevant data and get me pointed in the right direction - leveraging on the work that RobertSmall and botsapper and 3-wheeler have already invested. (BTW, my Hucho arrives any day now!) Since I have extra vehicles, and a garage, I do not have to drive the Insight during construction or modification. My approach goes like this.
1. Test the baseline car for Cd and fuel economy under know and stable conditions, as best as driving technique and conditions allow.
2. Using corregated cardboard, add a rear underbelly, AND build a "first effort" boattail, largely after the MetroMPG model of ribs, cardboard and garbage bag covering.
3. Test using yarn tufts and a webcam. Make any required modifications.
4. Test for fuel economy and Cd.
5. Once the "prototype" is firmly established and tested, then, and only then, move on to a more permanent construction method, such as fiberglas over foam.
6. Finish the project with a coat of professionally applied matching paint.
How does this sound strategy wise?
04-13-2010, 08:07 PM
PSmodder lurker
Your build plan seems reasonable. Do your least expensive beta testing with cardboard mock ups. Any revisions could be made easily & quickly. Your final shape could be done confidently and with proper materials & better fabrication techniques. Documentation & records are eagerly expected. We support your efforts and will follow your build progress here or on your own build site. Good luck.
04-13-2010, 08:27 PM
I like it too.
Keep us informed on your progress...
Jim.
04-13-2010, 08:38 PM
Left Lane Ecodriver
Jim,
I'm glad to see your enthusiasm, and I strongly encourage you to put it into action. And yes, if you can build a prototype much more easily than a well-finished final product, by all means do so.
Just a few comments on some of your steps.
2. If your boat-tail is as small and light as I think it will be, you may only need one or two ribs.
3. I'd love to see video of Insight tuft testing!
5. Your prototype will be cruder, and more angular, than a foam and fiberglass version, and the final version will be aerodynamically better. So if it works on the cardboard mockup, it's definitely going to work on the fiberglass version.
6. A professional paint job would be a nice touch. On Sunday, I painted a few panels on my Insight, and the good news is that they look fine from three feet away.
Keep us posted.
04-13-2010, 11:48 PM
A "3 foot paint job" is pretty good for a non-professional!
Subscribed, and watching this thread with interest.
First one to record tuft testing of a 1st gen. Insight boat tail prototype wins! :P
04-14-2010, 12:30 AM
I would advise against the garbage bag coverings, I tried it on my mirror deflector, and it made a ton of noise, flapped in the wind, and pulled air in somehow making it into more of a balloon. If you are worried about the cardboard getting wet, remember you plan on testing in good conditions, and don't have to drive it on days that are poor. Also, you can look into the used campaign sign plastic if you want to go an intermediate route. I would suggest you do coast down testing to get the Cd and Crr of your car to begin with. Then when you make changes, you can repeat the testing to see the difference. I have done coast down testing a couple times now, and I have found it is more post processing than anything, and there are a lot of us around the forum that can help with getting you started if you need. I think you will do well to just continue the lines of the Insight, since it is already super sleek. I once saw a picture of an insight that had a custom built trailer behind it that was super long with a fin. I think it's Cd got down to around 0.12, which would be pretty amazing. If you get a back of car bicycle rack, you can do your testing easy without ever putting duct tape on your car (unlike many of us). Best of luck!
04-14-2010, 08:54 AM
wyatt,
I think one has to use a layer of contact cement to hold the gargage bag material in contact with the base material, but maybe MetroMPG will confirm.
04-14-2010, 10:21 AM
I guess I never tried to glue it down, I just figured that it was temporary, and thus not worth spending too much time protecting.
04-14-2010, 05:08 PM
#9 (permalink)
PSmodder lurker
Try 3M Blue 72 spray adhesive. Great tack, low soak & repositionable. Works w/ all your material choices.
04-19-2010, 09:33 PM
#10 (permalink)
I've used garbage bags on several big cardboard prototypes. Never had problems, and I didn't do anything fancy beside making sure it was taut and well stuck at the edges with good, sticky duct tape.
