Old 04-24-2009, 07:10 AM   #1 (permalink)
Enhanced large font
Thanks Dave.
Code hacks - EcoModder - Enhanced Large Font
I wonder if we could start a dev branch in the repository?
--Bill
Old 04-24-2009, 07:24 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Nice
re: repository, that becomes high maintenance is the only issue, with permissions and making sure the authors test every last thing and not assume nothing has broken.
Wiki means you get it working once and show as simply as possible how you did it (so no real need for #defines in the examples) and you are pretty much in the clear after that. i.e. when I changed brightness code for vfd, it orphaned many bits of brightness code, but since that wasn't interfering with the hack and would complicate the example, I left those changes out.
Wiki also means any ecomodder can use it by default.
re: fonts, yup only 8 user definable fonts in your standard issue 2x16.
Old 04-24-2009, 05:59 PM   #3 (permalink)
Awesome job, skelly! Can't wait to try this out!
Old 04-24-2009, 10:00 PM   #4 (permalink)
Originally Posted by dcb View Post
Nice
But... Wiki also means that in a year it could be totally out of date. A branch in the repository is just that, a development branch.
Example, I have no idea what you have in 0.80. Sounds like a lot of changes if you manged to shrink the executable by 2k. That said, when 0.80 is posted to the repository maybe I find that you've fixed the same things I have, or you've made a lot of cleanups, or whatever... And now all of my work on 0.75 is useless.
Long and short of it, I would rather not be working on something if I know you're already working on it. I'm using RCS here to track my changes just because it is simple... But when 0.80 is posted into the repository I will have to merge my changes if I want to stay current.
Finally, I want to add that this project kicks ass. This goes for Arduino in general. We really are lucky to have such a hardware platform as open source advocates!! How about cruise control mods (with a second Arduino) based on the MPGuino output? There are so many possibilities!!
I love it. Awesome. Thanks for your work Dave.
Old 04-26-2009, 08:46 PM   #5 (permalink)
Thanks again for posting this, skelly. Excellent write-up as well. Readability of the big font is much improved!
Old 04-26-2009, 10:18 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
If anyone wants a visual on what is going on, here was the original writeup and a pic, it is tricky to do much with only 8 characters of course, but it is a fun exercise, kind of a puzzle
Old 04-27-2009, 08:51 PM   #7 (permalink)
Great looking font Skelly!
Old 04-27-2009, 09:13 PM   #8 (permalink)
I have to add that this is a simple hack only because Dave's original implementation was already there!
I didn't see this original write-up but the big font idea in general is very clever. I created an Excel sheet to play with the font design before I coded it up, I'll plan to post that in the wiki too once I clean it up a bit.
Old 04-27-2009, 09:25 PM   #9 (permalink)
dcb
needs more cowbell
dcb's Avatar
I do have a question, if anyone has time for such a riddle.
Do you think it is possible, with 8 custom characters, to do add capitol letters to the basic block numbers, all in 3char x2char format?
Old 04-28-2009, 09:38 PM   #10 (permalink)
Best I could do with the enhanced characters I posted to the wiki (below).
Problems with "M", "N", "Q", "V" (no different from "U"), "W". I think existing characters (slash, etc. could be used to help out the "M" and "N"...
Cd and blunt front ends Cd Aerodynamics 203 07-06-2010 05:59 PM
why is gearbox oil mod listed as large improvement in the 65+ mods modmonster EcoModding Central 16 02-10-2009 01:47 PM
Large GMC Van, possible improvements? Kalanco EcoModding Central 12 11-07-2008 10:12 PM
Large cars fud2468 EcoModding Central 42 08-30-2008 01:59 PM
Large Pickup Aerodynamic Mods buckyball Aerodynamics 43 08-02-2008 05:49 PM
