View Poll Results: What color?
Ford Racing Blue 1 25.00%
Green 1 25.00%
Other, make suggestions 2 50.00%
Voters: 4. You may not vote on this poll
Old 09-28-2020, 12:56 PM   #11 (permalink)
I didn't know if powder coat likes Bondo.
Anyone who's seen World's Fastest Indian will know where to get lead, although IIRC it is a tin-lead alloy. Eastwood company sells it.
Two wrongs don't make a right, but three lefts do.
Old 09-29-2020, 10:27 AM   #12 (permalink)
Powder coat ovens run at 450 degrees, but that doesn't mean the parts get that hot. Bondo degrades around 300 IIRC. I remember the powder coater we used being really fussy and bead blasting everything because body fillers contaminated his oven and fubared up following runs
I was suprised that one could still actually use and buy lead bars anymore. I know my fishing weights are steel, I cant buy decent solder, and the Washoe health department is pissy about repairing my 75 year old house.
freebeard (09-29-2020)
Old 09-29-2020, 12:24 PM   #13 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Most powders "flow out" at 450 degrees. Then you decrease the temperature to 400 degrees until the powder sets. Usually 20 minutes.
Flow out is when the powder goes from the dull powder look to when it melts and bonds together.
Before flow out
After flow out, which is pretty much the end result in regards to color.
I have read that you can use things like JB weld that are rated for those temperatures as an alternative filler.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
The Following User Says Thank You to M_a_t_t For This Useful Post:
Xist (04-23-2021)
