Old 07-18-2013, 07:00 PM   #1 (permalink)
Big Truck - '96 Dodge 3500
90 day: 18.75 mpg (US)
Comeback mods
So I purchased a 1996 Dodge Cummins diesel to Eco mod. First tank with no mods 19+ mpg from a 8000+ pound truck. Then the heat wave hit, AC on all the time. MPG dropped to 16+ mpg. The AC worked great at low speeds/rpm, warm at higher speeds/higher rims. AC was overcharged by more than 1/2 pound increasing the pressures and making the engine work harder. Mods this week after AC recharge with proper amount of freon, straight pipe cat and muffler delete, (removed at least 50 pounds), removed mud flaps, removed chrome wheel covers. Planned mods grill blocks and taller tires
Old 07-18-2013, 11:51 PM   #2 (permalink)
Put a muffler on the damned thing.
Old 07-19-2013, 01:25 AM   #3 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Do everything this guy did, then you're set
http://ecomodder.com/forum/showthrea...5-a-26259.html
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 07-19-2013, 02:32 AM   #4 (permalink)
90 day: 29.78 mpg (US)
A bed cover will likely be your number 1 mod for fuel efficiency.
My 1998 has a mechanical fan that always runs and moves quite a lot of air even when the clutch has it "off". You might do well to switch to electric fans.
Old 07-19-2013, 04:00 AM   #5 (permalink)
I had the down pipe fall off the back of the turbo on a 1990 cummins. It wasn't nearly as loud as you think it would be.
I am running down pipe only on my diesel and all you can hear is the whistle from the T76's turbine. The plus side is I never see any deer or elk when I drive at dusk/dawn or at night
Old 07-19-2013, 04:27 AM   #6 (permalink)
I know turbos attenuate some noise. Is this one a turbo? Either way, the diesels going down my street- a residential area- may or may not have complete exhaust systems but even so they are easily identified by sound as diesels. Erm, that isn't because they're whisper quiet either.
Old 07-19-2013, 08:47 AM   #7 (permalink)
It only takes money
I plan on a few other mods. The good bed covers are $400 ~ $800. If the can give a 1.5mpg increase it would pay for it's self in 18 months.
The electric fans are $600 ~ $700 and should pay for it's self in 12 months...
Now modded. Straight pipe, silencer ring delete, mud flap delete.
Old 07-19-2013, 11:59 AM   #8 (permalink)
MPG back up
278.6 miles 13.018 gallons 21.4mpg 60 to 70 mph with the AC on !!!
