Old 02-09-2009, 09:40 PM   #1 (permalink)
Compensating for tire size
I have slightly oversized tires on my car which throws off my speedometer. Until now it hasn't mattered but since I am installing the MPGuino it is an important factor. I have the circumference of the original tires and the current ones and I need to factor that into the MPGuino as well as keep it in mind when calibrating.
What would be the best place for me to factor this in... dialing in -or- hard coding it?
Than You.
Old 02-09-2009, 09:52 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
in the setup screen, adjust vssPulsesPerMile down by the percentage that your speedo is low. Compare the results with some hiway markers over many miles and fine tune.
Size of hood vent IkoIko Aerodynamics 32 11-30-2020 05:47 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
MPGuion program size question? r3tic OpenGauge / MPGuino FE computer 3 12-21-2008 02:43 AM
What effect from tire size and type? PonchoBuick EcoModding Central 1 11-17-2008 04:03 PM
change in tire size mully General Efficiency Discussion 8 09-28-2008 08:13 AM
