05-03-2010, 10:26 PM
#11 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Originally Posted by elhigh
Because it keeps working, yes?
Well, yeah. Basically, that's why. Besides that it's never caused a problem, and I can't afford to let someone else do my work for me, if I am capable of doing it myself.
05-04-2010, 08:48 AM
#12 (permalink)
+1 for partsdinosaur.com, I have bought a lot of parts and been happy with them.
Prius MFD fuel Log
Prius Gallons at fill up Log
05-15-2010, 12:38 PM
#13 (permalink)
go with gapless rings while you're there.
05-16-2010, 01:38 AM
#14 (permalink)
ok, so heads done, getting ready for the bottom end rebuild, when I get the berry hone, what grit should I get? I've found them in a large variety of grits. from about 80 grit all the way up to about 480. also The only calipers I have access to measures in tenths of an inch. Are the cylinders 2 7/8 inch or 3 inch?
12-24-2010, 12:00 AM
#15 (permalink)
Same question +1 what grit to use when buying a Berry Hone, when doing rings?
I bought a '94 Metro the read 0 on ALL three doing a compression check is that right, or my valves just toasted. The lady "seized it" in Sept in Southern Utah going down the High way, but it turns over just fine. Paid only $300 for the car, but it won't start...?
Aaron
12-24-2010, 12:18 AM
#16 (permalink)
Bus - '94 Ford School Bus huge Stupid - '01 Chevy Blazer LS 90 day: 21.38 mpg (US) hawk - '00 Honda Superhawk
12-30-2010, 02:34 PM
#17 (permalink)
Before buying anything for the honing, look into what it would cost to have a machine shop do the work. They have better honing tools, but more importantly they have better measuring tools (and know how to use them). As it stands you don't know what the bore size is to + or - .050", you should be able to measure it to .0001" and tell how out of round, and tapered.
I'm not saying you shouldn't do it yourself, but you'll need to buy some stuff (and learn how to use it). FYI, there are some amazing prices on ebay for old machine shop tools, but you'll need to be able/have someone calibrate them.
12-30-2010, 05:26 PM
#18 (permalink)
I've used Total Seal rings many times. I'm done with that. It seemed like a good idea, and it works for some. However, I've seen more unnecessary failures with Total Seal rings. Carbon is a HUGE problem.
12-30-2010, 10:02 PM
#19 (permalink)
get everything balanced while you are there.
port the head since its off.
and if you really want get a new cam and chuck her in
get some real good mpgs that way
12-31-2010, 01:50 AM
#20 (permalink)
Question for you guys on the "compression test I did"... I couldn't get a reading off any three of the cylinders when I tried? But placing your finger near the plug hold, they sure pulled and displace air- I had all three plugs out when I did it, its that incorrect? After the fact, I thought "maybe I should have left the other two plugs in, while testing each cylinder...?
Maybe I need to try again, if I did it wrong?
Thanks,
Aaron
