Old 06-05-2009, 11:15 AM   #1 (permalink)
Sealing the areas around the radiator
I touched on this idea a while back in my Paseo build thread. I took some foam pipe insulation and filled the gaps around the frame and radiator as shown below.
Before
After
Before
After
However, I honestly don't think this helps very much since there are much larger holes elsewhere where air can bypass the radiator. For example, there is a gap around each headlight hole. So, the idea behind this thread is, how can we effectively block off the other areas, or duct air to the radiator to eliminate air leakage around it?
Old 06-05-2009, 12:33 PM   #2 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
I was thinking coroplast for the large areas and basic duct shape from the inlet.
Old 06-06-2009, 11:44 PM   #3 (permalink)
is not covered in bees.
Istas's Avatar
Honda - '05 Honda Accord EX
90 day: 27.16 mpg (US)
Insight - '00 Honda Insight w A/C
90 day: 66.55 mpg (US)
Send a message via AIM to Istas
Yeah, coroplast seems to be a popular material for this kind of job. Also, perhaps some expanding spray foam? Though I imagine that would be a pain to clear out if a repair needed to be made. Also need to keep in mind the heat from the radiator, I don't know how the foam would react.
Old 06-07-2009, 03:58 AM   #4 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
one thing to keep in mid is where your engine picks up it's air... it could be an area direcly or indireclty fed air by an "air leak" around the rad.
i found in a grillblock experiment that fe can suffer is the airflow to the engine is restricted even if aero is improved.
just mention it so you can look at the big picture.
Old 06-07-2009, 08:16 AM   #5 (permalink)
Now block the big gap where the bonnet catch goes, to see a bigger difference ?
Just like these "cooling plates " do
Old 06-07-2009, 06:39 PM   #6 (permalink)
Jalilah - '07 Chevrolet Cobalt LT
90 day: 40.57 mpg (US)
... I can't tell the difference in the first two shots. Great idea to do this though. The more air you have going over the radio, the less you you need to let through the openings in the front.
Old 06-08-2009, 11:04 AM   #7 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
My thoughts exactly. It allows for a smaller opening in your grille block therefore better aerodynamics. Mind you Stevie, my radio is mostly off so i could block it up completely!
ollie
Old 06-08-2009, 11:10 AM   #8 (permalink)
ollie
If your radio contributes that much to drag, Might i suggest getting it repaired?
Old 06-08-2009, 11:36 AM   #9 (permalink)
vtec-e's Avatar
Kachow!!
Old 06-08-2009, 05:12 PM   #10 (permalink)
Ooo.. Found the seal in Picture 2. On top of the radiator. Goodness, I need to get glasses.
Radiator block + EOC vs. heat soak some_other_dave EcoModding Central 6 05-16-2009 01:02 AM
S10 radiator fan changes? bennelson EcoModding Central 29 12-29-2008 07:54 PM
Air sealing!!!! rjacob Saving@Home 5 08-20-2008 08:29 PM
5 min radiator block aeromod bennelson Aerodynamics 20 02-24-2008 10:40 PM
Ecomodding Smaller Radiator of Choice? XFi EcoModding Central 2 01-22-2008 04:53 PM
