Old 09-27-2013, 10:37 AM   #11 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by HHOTDI View Post
so what's the news/update on the Diesel Bike...? :{)
I did get this engine:
http://ecomodder.com/forum/showthrea...sel-26311.html
Haven't really done much but putter with the engine a little
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 10-21-2013, 05:16 PM   #12 (permalink)
Very interested to see the result!
Old 08-23-2015, 08:18 AM   #13 (permalink)
Originally Posted by Michael Moore View Post
There have been various car-engined motorcycles like the Shifty and Amazonas. Some of them used the car trans but converting that to sequential shifting may not be a trivial task. You might have an easier time, considering the torque available in an auto engine, going with an automatic transmission instead of manual.
The Amazonas is fitted with a Volkswagen air-cooled engine and the 4-speed transmission, but its secondary drive was through a chain. IIRC it still had the differential assembly, but it was welded locked and had the ring mounted in the same side as in the earlier Kombi in order to reverse-rotate as it was now behind the engine.
Anyway, if I were going to build a motorcycle with a car engine, if I were going to use an inline-4 instead of a flat-4, I'd probably mount it transversely and attempt to get it shaft-driven instead of chain-driven.
Old 08-23-2015, 08:50 AM   #14 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
Way too ambitious. You will never finish it. Too big and heavy to wheel out of the garage.
Old 08-28-2015, 03:04 AM   #15 (permalink)
Might still be easier than a Boss Hoss. Anyway, if there is even a V12 motorcycle made around a Lincoln Zephyr engine, a Volkswagen-powered might not be any rocket-science. BTW a few years ago I saw some pictures of a Honda CBR 1100 repowered with a Volkswagen Diesel.
Old 09-03-2015, 12:42 AM   #16 (permalink)
I would look for a 10 hp. V-twin industrial engine to ease the vibration issue. The tricky part may be finding the right transmission.
Old 09-04-2015, 10:05 AM   #17 (permalink)
In a last-case scenario, I would eventually consider to just get a centrifugal clutch like the one used in the Mobylette, since it's alleged to work in a way rather similar to a CVT.
