Old 06-17-2010, 10:51 PM   #1 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Continental Eco Tires......
Continental introduces fuel-saving, all-season ProContact with EcoPlus technology - Washington Times
Well, it's just a smart thing to do......
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-18-2010, 04:07 AM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
mcrews -
Yeah, I like these. They're on my short list for my next set of tires.
CarloSW2
American Solar Energy Society
Old 06-18-2010, 12:29 PM   #3 (permalink)
Work In Progress
Black Knight - '08 Toyota Yaris
Send a message via AIM to honestabe
Too bad they don't come in 13's
Old 06-18-2010, 06:19 PM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
honestabe -
Yeah, that is a shame. They only come in 15/16/17/18 wheel sizes. Here is a comparison of my current ContiProContact tire (on the left) to the ProContact EcoPlus version :
It looks like the same tread pattern but with wider gaps. It's funny. *IF* (big if) these pictures are the same scale, the grooves on the EcoPlus are narrower. Therefore, that would imply to me that the total contact patch is the same. Do you know what I mean?
CarloSW2
Old 06-19-2010, 01:52 AM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Hello -
I went and looked closer. The ContiProContact line of tires has slightly different tire patterns as a function of size. Here are my ContiProContancts when new as compared to the ProContact EcoPlus tires :
What you can see is that I only have two "middle treads [ribs]", probably as a function of tire size. Tirerack is showing a photo of a larger size tire of that brand of tire.
I would make the claim that my old "standard-issue" ContiProContact treads are already pretty close to the EcoPlus treads.
CarloSW2
Old 06-19-2010, 06:49 AM   #6 (permalink)
Tire Geek
CapriRacer's Avatar
cfg83,
As you found out, unless you compare the same EXACT size, you'll have problems drawing conclusions about the tread pattern. It is fairly common for small widths to come in 4 rib patterns where wider width tires will have 5 rib - and I've even seen 6 ribs used for extremely wide tires.
Second, OE tires will break up the pattern within a tire line. The vehicle manufacturer may demand a particular "look", and that may result in more groove width (or less!), more sipes per inch (or less!), and the pattern would be adjusted according - and slightly different than the "standard" for the rest of the line. - and, of course, each vehicle manufacturer would have different specs and desires, so the resulting patterns would only resemble one another.
- BUT -
The most important thing in rolling resistance is the tread compound. The tread pattern hardly has an effect on RR at all (except for the amount of rubber used). Simply changing the tread compound can have a profound effect - up to 60%. I can easily imagine that these tires just benefitted from an evolutionary development in rubber chemistry as have many of the other recent new offerings from other tire manufacturers.
BTW, Rolling Resistance is traded off with Treadwear and Traction (especially wet traction) within tread compounds. Tires with great RR will have poor treadwear or traction. The trick is to select a tire that has a good compromise that fits your needs.
Old 06-19-2010, 01:11 PM   #7 (permalink)
...beats walking...
Originally Posted by CapriRacer View Post
...The most important thing in rolling resistance is the tread compound.
...exactly! it's how much silica (sand) or other magic-mojo stuff (orange peels?) they mix with the rubber.
Old 06-19-2010, 05:37 PM   #8 (permalink)
Tire Geek
CapriRacer's Avatar
Uh ..... Mmmmmmm ...... not exactly.
Silica just changes the proportions a bit. Needless to say, tires with good RR have more silica, but silica also negatively affects treadwear and traction, which can be compensated for!
Old 06-19-2010, 05:39 PM   #9 (permalink)
...beats walking...
...I believe the OP was about LRR, not treadwear and traction.
Old 06-19-2010, 05:54 PM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
CapriRacer -
Thanks for the info on comparing treads. I think of it as reading "tea leaves" in some sense, but the visual is all we have to work with, so I am looking for "general rules" in terms of what I see.
This is almost a win-win for me. I could get a new set of tires with essentially the same tread design, so the "road feel" should(?) be pretty close. At the same time, I am driving tires with "new Eco chemistry".
I do wish they came in 51 PSI, but I can easily live with 44 PSI.
CarloSW2
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
My Continental Contact-Pro Tires cfg83 EcoModding Central 16 05-08-2010 01:33 PM
Bridgestone Tires and LRR gone-ot EcoModding Central 30 05-04-2010 12:31 PM
New Wheels & Tires trikkonceptz Success Stories 9 11-03-2008 02:05 PM
