Old 01-26-2008, 02:48 PM   #1 (permalink)
Hyundai Accent - '01 Hyundai Accent
90 day: 38.4 mpg (US)
Gixer - '97 Suzuki GSXR600
90 day: 43.12 mpg (US)
convert gas engine to run on ethanol
I was curious if it would be possible or practical to convert a car designed to run on gasoline to run on E85. From what I understand, the main problem with running E85 in a car not designed for it is that the ethanol is corrosive. After a while it would eat up the fuel lines and pump. So those would need to be stronger, but what else? Would this require a stronger fuel tank and injectors. Perhaps even something internal to the engine?
Also, where I live (kansas city) E85 is about 50 cents more than regular unleaded. In another city (columbia, MO if you must know) I've seen it at 50 cents less than regular. What's the deal with that.
Old 01-26-2008, 03:57 PM   #2 (permalink)
Send a message via AIM to Gone4
E85 runs at an octane of 100-105 generally. Your car needs to be modified for a higher compression ratio to suck every bit of energy out of the E85. If you leave it at a normal compression ratio you will be losing some efficiency. Flex fuel vehicles are designed at the lower compression ratios for gasoline so they do not run E85 under ideal situations.
Someone else can probably give more practical details on modifications required, but one of the problems is E85 is acidic and electrically conductive. This means you need to remove any bare aluminum, magnesium, and rubber. This means you need to put in stainless steels tanks and fuel lines, sometimes lined with plastic. Also some motor oils are slightly base to eliminate the acidity of E85 and reduce wear and corrosion.
Old 01-26-2008, 04:04 PM   #3 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
A new gas station opened up just a few months ago a few miles from my house.
It has the only E85 pump I have ever seen. I looked close at the pump to compare numbers. It costs about 50 cents a gallon less than regular unleaded.
That appears to be mostly because it is taxed very different than the standard fuels - you guessed it, by about 50 cents!
I have also heard that there is less fuel efficiency with E85 than gasoline, so you really aren't saving on cost per mile.
Also, I am in the Midwest, which is the Middle East of Ethanol, cost in other parts of the continent will vary.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-26-2008, 05:19 PM   #4 (permalink)
We've done fuel testing on E85 at my university on a combined fuels research engine and this only held true if we kept the compression ratio for gasoline (pretty low). Once we increased compression ratios we immediately saw better efficiencies out of the fuel. We also did some testing with the timing and got some improvements out of tweaking that, moving it slightly further from top dead center.
Old 01-27-2008, 09:21 PM   #5 (permalink)
cbergeron's Avatar
aerospire - '95 Ford Aspire
90 day: 56.92 mpg (US)
Hindsight - '00 Honda Insight
Can you destroy a gasoline _engine_ by running E85 in it? I know it can corrode the fuel lines on older cars (pre-1990), but I've heard someone say it will cause the engine to seize up because of the higher octane.
Ethanol also burns much cooler than Gasoline, so it's better for your engine in the long run.
Thanks!
Old 01-27-2008, 10:14 PM   #6 (permalink)
No_damage_i'm_aware_of- been running it for years.
Old 01-27-2008, 11:53 PM   #7 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
I played around with varying mixtures of Ethanol and did not take a big hit in FE until I got above E50. Up to that point I was seeing about a 10% decrease in FE. So If E85 is really cheap just blend a mixture until it get to that point where the FE starts dropping beyond your break even point.
"Judge a person by their questions rather than their answers."
Old 01-28-2008, 12:05 AM   #8 (permalink)
Lazarus: I have had similar experience with E85; not at all like those who project mpg losses based on BTU calculations. No doubt, they've never even tried it.
I will say, even above "E50" I didn't see more than about a 15% loss. The main caveat I'd throw out there is to expect some cold start and driveability issues if you go above E50 in below zero F weather.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Automotive X Prize - would a modded Civic VX make it? Krieg EcoModding Central 31 01-02-2008 07:06 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
