Old 02-24-2010, 07:25 PM   #1 (permalink)
Geo Metro Fast Idle Problem?
anyone had a fast Idle problem with there metro 1.0 engine? If so How did you fix it.
Old 02-24-2010, 07:44 PM   #2 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Honda Accord LX
90 day: 35.57 mpg (US)
is this intermittent? just happen during the cold months?
i bought a 26yr old used accord, it was idled too high from the day i bought it last august.
it was consistently too high, even for the warm months.
i found two screws under the carb that allowed me to drop it to about 500rpms.
you may have a fuel injected engine, but if your idle is consistently too high, even after it has warmed-up, i;d try to find the idle screw or a chilton book to point it out.
i have noticed that on rare occasions my car may idle too high. i place my foot under the accelerator and lift the pedal to lower the rpms. this is very rare that i experience this, but i assume it's linkage.
i hope this helps.
single person car thread
Old 02-26-2010, 11:02 AM   #3 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
What year Metro? You shouldn't have to screw around with the idle adjustment unless somebody else has screwed around with it first. Check for vacuum leaks.
Old 02-26-2010, 09:43 PM   #4 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
If it's a 1989-1995 engine then read this thread................
High Idle
GeoMetroforum.com - got mpg?
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Restoring a 1989 Geo Metro IheartGeos Introductions 18 02-22-2010 01:00 AM
Idle Speed Adjustment '89 Metro SirKeats DIY / How-to 7 02-08-2010 02:23 PM
My 1989 Geo Metro Story owlafaye Introductions 2 10-05-2008 06:31 PM
1990 Geo Metro Idle test cinaroh EcoModding Central 2 07-08-2008 10:15 PM
