10-13-2010, 05:12 PM
This thread is in the EcoModder Project Library |
Wiki Mod
Engine off coasting on my matrix
I want to be able to coast with the engine off but leave the ECU, dash, & scangauge on.
From my searching it looks like what I need to do is make a kill switch for my fuel injectors. I went digging through my low voltage scrap wire box and found a 12v 40A relay that came off a HID kit. It is designed as a normally open circuit but I think I can make that work bu using a normally closed momentary switch.
My issue is finding the Injector fuse, any idea as to which one that might be on a 2006 Matrix?
All I saw in the fuse box that might be it was a 20A EFI fuse and a corresponding EFI relay. No hint as to what EFI stands for.
Ideas?
Hints?
10-13-2010, 05:19 PM
Yeah, that dash reboots slooow...
EFI is electronic fuel injection, but that circuit seems to contain a lot of stuff normally, likely the computer that controls all the dash stuff.
10-13-2010, 05:22 PM
Wiki Mod
The dash does boot slowly.
There is a EFI 2 (15A) and and EFI (20A). Which one does what?
10-13-2010, 05:31 PM
Coasting Down the Peak
Take the fuse out and see if the car starts.
10-13-2010, 05:37 PM
Wiki Mod
that might work, but it will not tell me what else is on the circuit.
10-13-2010, 07:28 PM
Wiki Mod
I did some searching for wiring diagrams. I found one for a 2003 matrix, my 06 should be similar but not exactly the same.
Anyone want to read these and give me a none EE description?
What does the EFI fuse do?
If these do not help I have 20 other pdf to sort through.
Page 1
Page 2+3
4+5
6+7
8+9
Thanks!
10-13-2010, 08:03 PM
Don't they come back online when you turn the key back into its normal driving position (II) ?
If I put it back to II too fast, even the engine will come back on !
10-13-2010, 08:49 PM
Wiki Mod
Dash does but I do not like power cycling the ECU. I do not think that the SC comes back on (or it takes a while).
10-13-2010, 08:56 PM
#9 (permalink)
Neddy Seagoon
All I do with my Vibe is to stick it in Neutral, turn the engine off with the key, wait a few sec's turn the engine power back on with out hitting the starter and coast. This way I still have power steering while coasting, then bump start it when it necessary. My ScanGauge is in Hybrid mode so that stays on, car will coast quite a way.
Neddy
10-13-2010, 09:11 PM
#10 (permalink)
Wiki Mod
Neddy
I will have to try this on one of my mile long coasts and see what happens, it has been a while since I tried this.
