Old 03-15-2014, 12:50 AM   #41 (permalink)
sjgrimsley's Avatar
Trans Am - '82 Pontiac Firebird Trans Am
90 day: 20.84 mpg (US)
Explorer - '95 Ford Explorer XLT
90 day: 19.02 mpg (US)
Originally Posted by Mista Bone View Post
Your original 305, the electric cooling fan(s) wouldn't kick on until 235-240...which was known to cause starting issues on the later TPI motors.
I had an 86 WS6 TA, 305 TPI Peanut Cam, used to be on Thirdgen.org.
I even have articles from Car & Driver about the Gale Banks 200 mph speed run.
If I'm remembering correctly, the e-fan didn't come until '85 and only the H.O. 305 got it until the next year. Mine came with a clutch fan though. Started out as the powerhouse 145hp LG4. It was swapped latter for the H.O. L69 and the ECM was carried over along with the e-fan. It ran almost like a stout 350 if you can believe it. Now it's got a 400 small block from a '72 Caprice. Fully worked over with pretty much a peanut cam. Dual fans from the 98-02 f-body (same p/n as C5 Corvette) and everything is controlled by a 2003 Corvette PCM. Low speed fans at 210° and high speed at 220°, I think that's how I set them.
I've seen that Gale Banks 'bird before online. Didn't it weigh over 5,000 lbs to combat lift at those speeds?
Fully sequential port fuel injection
406 sbc 350hp @4800 425lb-ft @3600
4L60e trans .70 OD, 3.23:1 rear, 26" dia. tire, 1,600rpm @55, 2,050rpm @70
Old 03-15-2014, 01:59 AM   #42 (permalink)
You are likely talking about the 300 mph land speed car, not the street car....which was same color as yours.
The 200 mph small block
Banks Power | Super Trans Am
A few years later there was a 427 twin turbo F Body that was reported of doing 240 mph and that is when Gale Banks decided on a salt car. Now look at what he is doing with diesel power with out all the sooty exhaust.
