Old 03-16-2011, 03:40 PM   #51 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
For those of you who think arbitrarily adding EGR is a good thing I suggest you read the following.
http://www.iaeng.org/publication/WCE...p1548-1552.pdf
Although in some cases it is possible to get better mileage with EGR on a diesel it takes just the right amount, coordinated with the right injection timing, for the particular fuel load and rpm. Otherwise diesel get better mileage without EGR.
Old 05-08-2015, 04:30 AM   #52 (permalink)
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
I have a crazy cools EGR idea I'd like to try. A classic Gasoline powered VW Bug. Interestingly the first EGR Bugs in California had an air-cooled EGR cooling coil. I was thinking of not only using that, but tapping into the heat riser where the exhaust has already been cooled by running along the intake manifold. The main idea I have with using cooled EGR in a gasoline engine is to lower combustion temps enough in order to run lean at WOT.
Increasing EGR flow for better mileage Daox EcoModding Central 232 01-26-2015 10:43 AM
Trouble Code PO401 EGR Flow Insufficient Detected Ford Man Off-Topic Tech 4 12-09-2011 12:45 PM
Hey Civic VX owners - I need your help - please test your egr valve jadziasman Off-Topic Tech 5 06-27-2010 07:56 AM
Metro EGR passage cleanout needed -- any tips? lyd DIY / How-to 2 09-30-2008 11:11 PM
EGR dilution for more MPG? cfg83 EcoModding Central 18 04-29-2008 09:11 PM
