Go Back   EcoModder Forum > AltModding > Saving@Home
Old 04-16-2012, 09:38 PM   #1 (permalink)
heading for 40
redorchestra's Avatar
Hong Kong MTR - '98 Bombardier/ nee Adtranz A-Stock 5 paired doors
90 day: 102.63 mpg (US)
coroplast cold frame
I just built something Ive been dreaming of building for a long time. from a single 4x8 sheet of uv coroplast I made two 4 foot long mini row cold frames. I'll post up a pic in a day or so. I still need to work out a vent for each end.
I will also post a pic of a clay form for making newspaper seedling pots. I formed over 75 seedling pots but my wife took 25 of them to plant sunflowers with her grade 1 science class
that left me with 53 pots. I planted 3 types of pumpkins, three types of tomato, romanesco, purple cauliflower, pickling cucumbers, swiss chard, giant sunflowers and teddy bear sunflowers . I have some lettuce mix for the mini green house, and some spinich to plant in an uncovered bed.
does my sig work now?
Old 04-17-2012, 08:01 PM   #2 (permalink)
heading for 40
also planted watermelons and muskmelons
Old 04-20-2012, 09:50 AM   #3 (permalink)
Ecobalt's Avatar
I wish I had built automatic lifters for the lites when I built my coldframe.
Old 05-13-2012, 09:46 AM   #4 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
A quonset ganzfeld for plants....
When you made the paper pots, do you use any adhesive on the paper? Just water?
Noah Webster, 1787
Old 05-13-2012, 07:05 PM   #5 (permalink)
heading for 40
no adhesive,i actually use a tabbing system. i roll the paper about 5 times to make a rim. then i wind the rim at the top of the mold. i spin the paper to fold it down into the tapered shape then press the excess paper into a small divot at the bottom. after i remove the mold i rip the rim near the end piece so that i can unroll a one inch section and i tuck it insde the pot. the soil holds the tab against the inside wall of the pot.
i just made twenty more today because i forgot to plant peppers.
this time i rolled some peatmoss into the rim and into he pot wall before i sealed it up. My last set of pots started to mold and i am afraid the seedling might be damping off.
Old 05-13-2012, 07:36 PM   #6 (permalink)
heading for 40
i did plant romanesco in it
