Gramps - '04 Toyota Camry LE 90 day: 35.87 mpg (US)
I didn't want to sit though that again, but oh well...
Heh. Thanks for taking one for the team!
I do like the Vanagon covers.
I already tried purchasing cheap hubcaps. The Forester ones that I showed in post five cost $58.50 and that is more than I want to spend for something that I intend to destroy.
I am necroing my own thread [maniacal laugh]!
I had these attached for a little while and I want to try this again. The main problem I saw was that zip ties break when attaching wheel covers. I did not think that having plastic straps rub on a metal edge helped. I thought filing that part of the hole to make it straight would help. How exactly did you guys zip-tie your wheel covers? I wanted to try a different method than I attempted before.
I use Velcro. Works great on rear wheels once you get used to them seeming loose all the time. Not so much on the front, due to wheel flex when cornering. I lost one before I could trim it, so I'm one-ended.
Frank
The Following 2 Users Say Thank You to fbov For This Useful Post:
