Old 06-08-2013, 01:39 PM   #51 (permalink)
Stand-offs on hubcaps.
I didn't want to sit though that again, but oh well...
The result is sort of like a Vanagon hubcap:
These fit a 14" wheel, otherwise I'd run them.
Old 06-08-2013, 08:16 PM   #52 (permalink)
90 day: 30.54 mpg (US)
Heh. Thanks for taking one for the team!
I do like the Vanagon covers.
I already tried purchasing cheap hubcaps. The Forester ones that I showed in post five cost $58.50 and that is more than I want to spend for something that I intend to destroy.
Old 02-24-2016, 11:58 AM   #53 (permalink)
I am necroing my own thread [maniacal laugh]!
I had these attached for a little while and I want to try this again. The main problem I saw was that zip ties break when attaching wheel covers. I did not think that having plastic straps rub on a metal edge helped. I thought filing that part of the hole to make it straight would help. How exactly did you guys zip-tie your wheel covers? I wanted to try a different method than I attempted before.
Thanks!
Old 02-24-2016, 01:32 PM   #54 (permalink)
Porter - '13 Ford C-max SEL
I use Velcro. Works great on rear wheels once you get used to them seeming loose all the time. Not so much on the front, due to wheel flex when cornering. I lost one before I could trim it, so I'm one-ended.
Frank
The Following 2 Users Say Thank You to fbov For This Useful Post:
aerohead (02-24-2016), Xist (02-24-2016)
