Old 01-11-2010, 10:10 PM   #1 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
tires rated for higher psi?
my 175/65r14 tires on my toyota echo are rated for max psi of 44 are there tires that have a higher psi rating? mine are the walmart goodyear viva -2's they are supposted to be llr (low rolling resistance) ,but they are no better than my old tires at least not yet and i have 30k on them.
Old 01-15-2010, 03:32 AM   #2 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I just bought a set of Nokian wrg2 tires and they are supposed to be LRR. They are working really well for me although I have not collected enough data yet. Incredibly quiet even on wet roads. Max 51 PSI with a canola silica compound. They have your size in an all season i3 I think. 620/A/A They are a very green comany as tire companies go. The first to offer non toxic tires.
Also there is the bridgestone RE92 XL which is an OEM for the fist gen Prius. They seem to be an OK tire and LRR. (50 PSI) Mediocre reviews though.
There is also the BS B381 which is the lowest RR tire going.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 01-15-2010, 04:04 AM   #3 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
moonmonkey -
I used tirerack.com to research tires rated at 51 PSI :
http://ecomodder.com/forum/showthrea...ires-2642.html
Mine don't seem to be available in your size, .
CarloSW2
American Solar Energy Society
Old 01-15-2010, 09:03 PM   #4 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
The Sumitomo HTR 200 is available in a 175/65-14 and a taller 175/70-14. Max pressure is 51 PSI. It's no B381, but it's cheaper and available in your size. And it's one of Green Seal's recommended tires. I wish they made them for 12" wheels.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
How many PSI do you run in YOUR tires? 1337 EcoModding Central 130 08-07-2014 08:35 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
SAE Paper 800087 – The Effect of Inflation Pressure on Bias, Bias-Belted, and Radial CapriRacer Hypermiling / EcoDriver's Ed 18 07-06-2008 06:36 PM
