Old 10-20-2012, 08:43 PM   #21 (permalink)
Cd
Ultimate Fail
Cd's Avatar
( My first thoughts are weight distribution and its effects on handling.
How will you tackle this problem ? )
This is going to be a really interesting project !
Old 10-20-2012, 08:54 PM   #22 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
The angles could also not be as bad as they look in the picture. Maybe you can try taking a picture from further back so we can judge the angles.
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
Old 10-20-2012, 10:34 PM   #23 (permalink)
EcoModding Smurfer
Smurf's Avatar
Dime - '95 Chevy S10 LS ExtCab RWD
Pickups
90 day: 18.23 mpg (US)
G/A - '96 Pontiac Grand Am
Team Pontiac
90 day: 32.74 mpg (US)
Sven, I believe he's using the CRX drive, with the motorcycle frame/swingarm modified for a static rear wheel.
HydroJim, it has to do with center of gravity, how low it is and where it is between the three wheels. In a 2F1R (two front, one rear) format, you typically want it between the front wheels, about 1/3-1/4th the way rearward. The TRex type trikes have barely any weight above the rear wheel, hence their ease of sliding out the back end but rarely tipping over.
I'm following this project closely, I've considered something along these same lines but with a Metro XFI.
Old 10-20-2012, 10:39 PM   #24 (permalink)
Though I would wonder about the possibility of doing a somersault if you braked too hard.
Old 10-20-2012, 10:51 PM   #25 (permalink)
this is were the car sits right now will get a fuel tank and battery and seats and people wheelbase is a longer now so tipping is hard. not saying cant happen just need to drive for that info hyperdriving no brakes
Old 10-20-2012, 11:57 PM   #26 (permalink)
EcoModding Smurfer
Smurf's Avatar
Pickups
Team Pontiac
This might give you some food for thought when it comes to shaping in the rear gap...
The Following 2 Users Say Thank You to Smurf For This Useful Post:
poobah318 (03-20-2013), Stacygifford (02-04-2013)
Old 10-21-2012, 05:54 PM   #27 (permalink)
Right now about 200 pounds on rear wheel after say ready for basic street
350 no driver no doors and will drive and see how it go. And thanks for the foam vid Will try that when the time comes This may help
Old 10-22-2012, 12:46 AM   #28 (permalink)
EcoModding Smurfer
Smurf's Avatar
Pickups
Team Pontiac
Your build already looks cleaner than that.
Old 10-22-2012, 11:59 AM   #29 (permalink)
thanks and I don't plan on pulling a trailerand slaming the brakes..
you don't want to know
Old 10-23-2012, 12:23 AM   #30 (permalink)
