Old 10-19-2012, 03:30 AM   #11 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
There is a flow image at the bottom I working on
never can get the flow 2 program to work only 1 so if any one can do one Would help.
I think you have to lower the back of the trike. The angle is too steep.
See attached picture.
I've used Flow Illustrator.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 10-19-2012, 10:50 PM   #12 (permalink)
Originally Posted by groundflyer View Post
Why?
Basically because I like the CRX bodystyle as it is. If I could get one to adapt that new 1.6L turbodiesel from the Euro-spec Honda Civic I'd do it...
But even retaining the 4-wheel layout I would not disconsider to adapt 2 independent Unit Pro-Link setups for the rear wheels to increase the cargo volume.
Old 10-19-2012, 11:53 PM   #13 (permalink)
EcoModding Smurfer
Smurf's Avatar
Dime - '95 Chevy S10 LS ExtCab RWD
Pickups
90 day: 18.23 mpg (US)
G/A - '96 Pontiac Grand Am
Team Pontiac
90 day: 32.74 mpg (US)
Or taper the back sides together alot.
Old 10-20-2012, 05:27 PM   #14 (permalink)
Will be moved in some need the tailights
I think you have to lower the back of the trike. The angle is too steep? bottom? top?
and its a roller
Old 10-20-2012, 05:30 PM   #15 (permalink)
pics
ID:	11705   Click image for larger version
ID:	11706   Click image for larger version
Old 10-20-2012, 05:47 PM   #16 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
I hope your body line isn't following the roll cage because that angle is way too steep.
If you haven't heard of the aero template, here is an example of how the template should be placed.
This shape would provide minimum drag which would maximize fuel economy
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
Old 10-20-2012, 06:09 PM   #17 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
A good rule of thumb is to not exceed 15 degrees taper. On the bottom you might do 10 to be safe, although with a skinny rear and single wheel you'll have to fair it to get any meaningful flow patterns back there.
Definitely go to the Template sticky in the Aerodynamics forum and throw the template over it. Jim has a very good example there; use the same technique.
I think you mentioned getting rid of the sharp corners on the rear. You need those to help flow detach smoothly.
Cool project. have you considered doing something smaller, like a 500cc or even a 250? The car shouldn't need more than like 15hp to cruise at 60mph.
Old 10-20-2012, 08:36 PM   #18 (permalink)
HydroJim's Avatar
excuse my ignorance, but this is something I've never understood. How can a trike be stable? it seems like the car would just tip over. Is there a secret to this? After I complete the Aerofocus I would like to start building my own car as you are doing here and a trike would really be nice, but I feel like it would just fall over.
Old 10-20-2012, 08:42 PM   #19 (permalink)
[QUOTE=Sven7;335395]A good rule of thumb is to not exceed 15 degrees taper. On the bottom you might do 10 to be safe, although with a skinny rear and single wheel you'll have to fair it to get any meaningful flow patterns back there.
Fair what ?
Thanks bottom is open to changing top is not.. at this time but Will be adjustable by 3" with air shocks
Yes thought about is but that would be later Two giant vortecs lol
Nope in the same car? well did you see the vid of my 8yo GD moving the car?
thats lite.
Fair what ?
where?
Old 10-20-2012, 08:43 PM   #20 (permalink)
All things can change Im just trying to drive it for now budget build. the slop is the crx upper line hood to tail so cant be all that bad. But thanks I did know about the templet
