Old 06-12-2009, 01:34 AM   #1 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
Cool CRX - What to do first?
Got a crx from a friend today. Almost 300k miles but it was mine for $500
Its my first crx as well as my first Honda. (So feel free to give me any tips)
Its a 5 speed although the Si makes me want to GO!
(which is why i like autos... as they keep me )
My friend said he gets 37-40 mpg with it.
The main thing I need to fix is rust.
The drivers door is sagging and one of the hatch hinges are gone.
So what would you experts do?
Past Present Future?
Old 06-12-2009, 08:33 AM   #2 (permalink)
#1 on my list would be damage control and maintenance. Check to make sure your brakes aren't hanging up, run some fuel injector/carb cleaner through it, check spark plugs and distributor cap condition. Basically, check all the easy/common things. I'd also address the rust issue as soon as you can, its not going to get any better on its own.
After you know your car is solid, then I'd start with the mods. Probably throw a grill block on it first and get a mpguino!
Old 06-12-2009, 10:50 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I want another one
Old 06-12-2009, 11:12 AM   #4 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Pontiac Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
I have wanted one since they first came out. What was it 84-85? I agree the first thing is check the tune up or just go do one. It's good for the brain... This way you know you are starting off from square one and other improvement or changes you make will have legitimate results. As long at the rest of the mechanicals are up to daily driving I would say start with locating a straight used fender.
Dean
1996 Pontiac Bonneville SE 3.8L V6
Old 06-12-2009, 12:03 PM   #5 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
Speed tape? check
Rust? check
Missing parts? check
Multiple colors? check
The good part is you could probably leave it parked with the doors unlocked, windows down, and keys in the ignition and it'd still be there when you came back ;-) If I had the time and resources I'd love a car like that.
Old 06-12-2009, 12:34 PM   #6 (permalink)
Grasshopper
Yeah I left it unlocked all night.
Just threw a club on it and disconnected the battery.
(plus I think there might be an electrical drain somewhere)
It runs pretty well
Heres my list:
Cleanup/Fix Rust (will take a while)
Rear Wiper Delete
Smaller Side Mirrors
Wheel Covers
MPGuino
Wheel Skirts
Grill Block
Old 06-12-2009, 01:32 PM   #7 (permalink)
PSmodder lurker
Had Hondas for mega-miles. The first thing to do on hi-odometer Hondas: Timing belt replacement. Belt failure is the worse news because there is zero clearance for the valves to clear the pistons when it catastrophically fails. The next is clutch inspection, maintenance and/or replacement. Go down ALL the list of maintenance recommendations and your Honda will keep on ticking. The first one I had, that I sold to a buddy is still running and should be +500K by now.
Then eco-mod it to your heart's desire, brah.
Old 06-12-2009, 03:55 PM   #8 (permalink)
Grasshopper
I think its a given that I have to get it running well.
I want the scoops on aero mods and driving technique.
Ive actually been doing a lot of coasting.
Clutch In at low speeds
Neutral in higher speeds
Redline up the hill (j/k)
I think we covered aero too, but feel free to chime in.
Old 06-12-2009, 04:22 PM   #9 (permalink)
Bellypan
Old 06-12-2009, 04:27 PM   #10 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Why change technique with speed? It doesn't matter what your vehicle speed is... the engine speed will be at idle while you're in neutral (unless you turn the engine off, in which case it doesn't matter if you're in neutral or clutching).
The problem with clutching for extended periods is that the clutch release bearing doesn't have a cooling mechanism. It will heat up, and eventually, it will fail. Best bet, regardless of speed, is just to pop the gear selector into neutral. (I don't even use the clutch pedal to take the selector out of gear... just pull it out while you're letting off the gas pedal, and it will slide right out.)
Which CRX? seanof30306 EcoModding Central 8 02-10-2009 05:52 PM
1991 Honda CRX - New Here... Hi, Everyone! adam62882 Introductions 4 09-28-2008 10:35 PM
New guy with a 1990 crx hf. gasnmyveins EcoModding Central 6 09-06-2008 01:21 AM
Repping the old school Hondas - 85 CRX HF 1GCRXHF Introductions 4 06-16-2008 01:14 PM
non-op '85 CRX, or '91 civic hatchback SirKeats EcoModding Central 1 05-16-2008 04:21 PM
