Old 02-25-2010, 10:22 PM   #31 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
0.3ft^2=43in^2. But yes, about the size of a mirror.
Old 02-25-2010, 10:28 PM   #32 (permalink)
90 day: 51.82 mpg (US)
I count a difference of 43.2 square inches (1 sq ft = 12 in * 12 in = 144 sq in * .3 = 43.2 sq in)
Buuuut... that list doesn't say "HF" on the 1st gen stats. It might be better than indicated.
I'd still go for the smaller, lighter one, personally. You can fix the Cd (and have fun doing it).
Old 02-25-2010, 11:00 PM   #33 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Buy it.
I had a 3 1st gen CRX's. I'd rather have them.
The handling issues aren't really issues at all, the McPherson setup is fine for extreme use with a set of decent coil overs and some lowering, which isn't really all that hard to do.
Hell, you can lower the front of the car up to 2 inches or so just by turning a couple nuts!
Check out RedPepperRacing.org for all the info you could ever use on the 1st gen CRX.
Old 02-26-2010, 01:06 PM   #34 (permalink)
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
Thanks for the advice and the help with dem maths. Topher: Are there any typical sneaky issues to look for with these cars akin to the pervasive front control arm mount rust problem on geo metros? Keep in mind that I'm not concerned with issues pertaining to the motor+trans in this situation.
Old 02-26-2010, 08:38 PM   #35 (permalink)
A Honda's a Honda's a Honda, when it comes to rot.
Check the rockers, floor pans, and rear wheel arch areas mostly. Check that someone hasn't bondoed the crap out of those areas and smoothed it out.
*EDITED section out because it applies to another generation of Honda*
There are no structural rust issues, though. Check inside the rear hatch area for breakthrough, as well. That'll be caused by sunroof drains, if it has one, but check anyway.
Old 02-27-2010, 12:38 AM   #36 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I seem to remember reading over at RPR that the panhard rod mount has rust issues. Yet on my 1984 Civic Wagon, that's the only spot that didn't rot out on me. And I've seen a 1st gen CRX that had the trailing arm area of the floor rot through and break. So even though they don't rot out as badly or as often as the Metros, I wouldn't skip a careful inspection of any critical areas.
Old 02-27-2010, 12:42 AM   #37 (permalink)
Not really structural, though.
They do rot, and it's something to look for, but it's not usually a deal breaker, as it won't make the car "unsafe" to ever operate again. The repair panel for it is very easy to line up, and you can actually repair the area with some sheet metal and fender washers, if you're really cheap.
It just keeps the rear end from swaying back and forth under the chassis by a few inches each side.
I'd still inspect it like crazy, if even just to get a better deal (if there was such a thing) on it. It's an old NY car... it's bound to have rot somewhere.
Old 02-27-2010, 01:06 AM   #38 (permalink)
The 1st-gen CRXes make very good race cars because of their light weight. So the "more primitive" suspension shouldn't deter you.
Then again, I really like my 2nd-gen 'Rex...
-soD
Old 02-28-2010, 10:52 AM   #39 (permalink)
Wonderboy's Avatar
Someone managed to buy it up before me apparently DURING that big snowstorm that just came through the area. Oh well, back to hawking CL.
Old 03-13-2010, 07:57 PM   #40 (permalink)
Wonderboy's Avatar
It's official! I just got back from picking up a 1988 CRX HF shell with no interior and one seat for $250. I'll start a new thread about the genesis of my CRXFi. The only thing that could've made this purchase more ideal is if the windshield weren't cracked Got a nice pair of axles for an additional $15 as well. Very exciting. I'll post pictures later, perverts.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Seriously! My 1994 Honda Civic DX Build Thread! JJMunoz EcoModding Central 29 02-18-2012 08:09 PM
Geo Metro XFi cam swap How To Johnny Mullet DIY / How-to 13 01-31-2012 09:05 AM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 10:31 PM
Starting to Mod my Xfi bbjsw10 EcoModding Central 140 04-14-2009 07:27 AM
