Old 09-15-2013, 06:44 PM   #1 (permalink)
Ecomodest
Jasen's Avatar
The Van - '97 Chevy Astro AWD cargo van
90 day: 14.03 mpg (US)
Custom UG install, faux touch screen
So I wasn't happy with attempt #1, not happy at all. Ok it was a fail, but I was on the right track, so I scoured the internet looking for something better.
Found these 3m Command mini hook's, and used JB Weld plasticweld epoxy putty to sculpt things to fit.
I used scotch tape on the bracket as a bond breaker so the plasticweld wouldn't stick to it. Mixed up some epoxy putty and worked in. After 3 hrs. cure time I was able to file and tune the plasticweld.
3m removable tape thingy.
Removed the dual lock industrial velcro and installed the new set up.
The UG bracket slips on the hook just like it would on a UG attachment system.
This work's much much better, a light press on the corner of the UG activates the button's nicely.
The 3 button contact point's on the mirror are a small and medium self adhesive rubber drawer bumpers stacked up.
Being a mad scientist is not as easy as it looks on TV
The Following User Says Thank You to Jasen For This Useful Post:
California98Civic (09-15-2013)
Old 09-15-2013, 10:57 PM   #2 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
That's wicked.
Old 09-16-2013, 12:04 AM   #3 (permalink)
Ecomodest
Jasen's Avatar
thanx 98
now I just have to figure out which gauges to run, I've changed them 3 times...
so far
Old 09-16-2013, 11:09 PM   #4 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
i like the idea but can't really visualize how it mounts, maybe i'm too tired to understand. could you gat a closer in focus pic where it mounts to the mirror?
i used the supplied clip, cemented an aluminum plate and cemented copper rods bent to attach to the ac vent. i would like to put it on the mirror though.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 09-16-2013, 11:42 PM   #5 (permalink)
Ecomodest
Jasen's Avatar
Wifes got the good camera with her up in Alaska so it's my crappy cell phone pics, sorry.
Let see if i can clear up how it works.
The hook
The bracket
I slipped the hook into the slot in the bracket, them pushed the epoxy putty in through the hole in the back of the hook to fill the thin slot of the bracket and reduce the gap of the hook to the thickness of the bracket. So I've recreated the section in the yellow box out of the hook, and the bracket slips onto it in the same manor.
Then I used the supplied 3m adhesive strip and stuck it to the mirror.
I was scrolling through the pages today while driving, it works great, just a light push on the corner and the next page popped up. I'm very happy with this 2nd design.
A couple crappy night shot's.
Hook, see how I put in the putty (light gray)
Bracket installed
California98Civic (09-17-2013)
Old 09-17-2013, 03:42 AM   #6 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Nice setup!
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 09-17-2013, 09:44 AM   #7 (permalink)
Not banned yet
deejaaa's Avatar
i will look at it when i get home. this comp is blocking the pics. thanks for the info.
edit:
i see it now. i like it.
