Old 04-13-2009, 03:09 PM   #1 (permalink)
Zippy - '06 PONTIAC WAVE 5DR
90 day: 38.73 mpg (US)
Premium vs. Regular
Anyone have any gains using premium vs. regular gasoline? I've been using Shell V-Power and i seem to get a 10% gain in efficiency.
Old 04-13-2009, 04:02 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
thebluelightbulb -
I use (mostly) Chevron 91 Octane. However, I have a Hot-Air-Intake, so the premium fuel is insurance HAI (hot-air-intake => lean-burn => higher octane is better to avoid knocking/pinging). Here are threads on same :
http://ecomodder.com/forum/showthrea...mium-3143.html
http://ecomodder.com/forum/showthrea...ades-4925.html
CarloSW2
American Solar Energy Society
Old 04-13-2009, 08:14 PM   #3 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I use premium fuel and get better performance/mileage from it.
GeoMetroforum.com - got mpg?
Old 04-13-2009, 09:25 PM   #4 (permalink)
90 day: 51.82 mpg (US)
Call me skeptical, but I'd like to see a controlled test.
Old 04-13-2009, 09:35 PM   #5 (permalink)
I think this is another one of those areas where "it depends" on a lot of factors. Engine design, engine management system (e.g. how exactly it reacts to pinging), driving style (P&G puts my car into the regime where it may knock/ping depending on other conditions), ambient temps, and on and on and on.
One thing is for sure: Over the long term, pinging is very bad for your engine.
The best way to tell if premium fuel helps is to do an instrumented test. Or, rather, a whole lot of instrumented testing. If it does help, then you get to figure out if the MPG difference makes up for the $$ difference or not.
BTW, in my car it doesn't seem to make any difference for MPG. But it does keep the car from pinging in the "worst" of circumstances--where it will with regular-grade. (And the tendency to ping appears to vary from fill to fill as well, even when using the same grade of fuel from the same station.)
-soD
Old 04-13-2009, 09:39 PM   #6 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Put some more E85 in your diet.
Old 04-14-2009, 08:56 AM   #7 (permalink)
morning,
it seems there is a wide variety of critisism regarding this. i'll go through another tank and see if there are any gains. chances are that i will to back to #87 just because a 10% gain in efficiency cancels out the cost of premium which is 10 to 15% higher than #87 in my neighbourhood. i have found that different brands of premium give me different results. Shell V-Power gives me the greatest gain while Crappy Tire #91 must be full of ethanol, not giving me the required boost for my test. too bad i don't have a dyno and a fuel monitor. that would give me the best test.
...thebluelightbulb...
Old 04-14-2009, 10:08 AM   #8 (permalink)
Unfortunately, tank to tank testing of anything is an exercise in futility for the vast majority of drivers (whose normal variation, absent any changes at all, is large). Far too many variables to possibly isolate just one as the cause of any change.
Old 04-14-2009, 12:30 PM   #9 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Only time I noticed a difference with premium was with the old 6000 wagon when towing a trailer. With over 200k on the engine, the premium stopped the pinging and restored some of the lost power when climbing hills, so I would make it a point to use premium when towing. If I didn't have it, I could really tell the difference. Other than that, never noticed a difference. Tried it for a couple tanks in the Celeb once but never noticed a difference in performance or mpg.
Winter daily driver, parked most days right now
Summer daily driver
Old 04-14-2009, 03:12 PM   #10 (permalink)
since there is a marginal or no increase in efficency compared to cost, i'll just use good ol' #87. i'll use premium only if i really need to do so.
thanks for the advice everyone!
Mercedes modded C-class: Cd 0.25. Up 7.5 mpg over regular model (with other mods). MetroMPG Aerodynamics 25 04-08-2013 04:57 PM
increasing compression, running on regular gas? Southcross EcoModding Central 33 04-09-2009 01:37 PM
My introduction to hypermiling the Smart Ptero Hypermiling / EcoDriver's Ed 12 10-28-2008 07:32 PM
Regular vs. Premium Tango Charlie General Efficiency Discussion 17 06-19-2008 05:19 PM
GAS is 4.50 for Regular in Los Angeles dsq EcoModding Central 10 06-06-2008 03:11 PM
