04-06-2010, 09:37 AM
#161 (permalink)
Did that... with my foot and a dead blow hammer.
04-06-2010, 12:48 PM
#162 (permalink)
Penetrating oil and a short sharp shock. Or several. Dead blow won't cut the mustard. A steel hammer is your friend here.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
04-06-2010, 01:05 PM
#163 (permalink)
Eeesh, steel hammer on my steel rims... I don't like that idea so much.
04-06-2010, 03:17 PM
#164 (permalink)
You don't have to cold forge them.
Firm tapping should do the trick. It's the vibration that loosens the rust bond.
I think that driving with loose lug nuts would be more damaging.
04-06-2010, 03:23 PM
#165 (permalink)
EcoModding Enthusiast
Seconded. Maybe a thin sheet of plywood between hammer and rim?
04-06-2010, 03:24 PM
#166 (permalink)
If it's paint chipping you are worried about try tapping from behind.
04-06-2010, 03:33 PM
#167 (permalink)
Another approach:
Not very good for FE, but drive a little ways with your ebrake on and bolts snug but not tight. Heat differential will expand the drum faster than the rim, shearing the rust.
04-06-2010, 07:32 PM
#168 (permalink)
lol, I laughed out loud at that one.
I ended up trying out protoge's suggestion. I put a 2x4 up against the rim and wacked it with a small sledge. A couple of swings and it broke loose. Now I have all 4 Ecopias on, yay!
04-07-2010, 02:01 AM
#169 (permalink)
And you don't have tinnitus! yay!
I'm here all week! boo!
04-07-2010, 11:13 AM
#170 (permalink)
Originally Posted by Daox
..I ended up trying out protoge's suggestion..
Hammer n duct tape, baby! If it doesn't move, and it should, use the hammer!
