Old 06-02-2014, 12:16 PM   #311 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
so, what was that in terms of Depth of Discharge (DoD)?
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 06-02-2014, 12:41 PM   #312 (permalink)
60% He is using 100Ah cells.
Old 06-02-2014, 12:48 PM   #313 (permalink)
skyking's Avatar
looks very do-able with that charging at work, for all but the nastiest cold spells. WELL DONE!
2003 TDI Beetle
2002 TDI Beetle
Old 06-02-2014, 01:16 PM   #314 (permalink)
I'm actually using 180 AH cells. I have my EV Display to set the "0-100%" fuel to only use 144AH max, or 80% of my total capacity.
Technically I only used 33% of my total battery capacity, but because I limit myself to act like my batteries are only 144 AH, I used ~40% of my usable battery pack. I know it's all confusing, but I set my EV Display so it's always on the safe side.
I charge at work so no matter what I'm fully charged at the end of the day. Heat would only use ~10 AH more and I will figure out what A/C will do. I am working on getting a full charging station at work so I charge faster. I also need to get some forced air to assist in cooling the charger on these hot days. I need to put some force air exhaust, I had an idea but didn't get around to it because I always was parked in the shade.
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
The Following User Says Thank You to TheSGC For This Useful Post:
Daox (06-02-2014)
Old 06-02-2014, 01:19 PM   #315 (permalink)
skyking's Avatar
That's it. done deal. Get busy racking up those EV miles now
2003 TDI Beetle
2002 TDI Beetle
Old 06-02-2014, 01:34 PM   #316 (permalink)
Whoops, thanks for the clarification. Sounds like you are good. I agree, start racking the miles up.
Old 06-02-2014, 03:52 PM   #317 (permalink)
I rack up 20K+ miles a year commuting to work, so these are going to add up fast!
Old 06-03-2014, 09:45 AM   #318 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Awesome! I am looking forward to seeing your A/C solution working. Are you still planning to use a DC treadmill motor for A/C power?
Old 06-03-2014, 11:01 AM   #319 (permalink)
Yeah, I have one with a pulley welded up to it that I am going to start out with. I'm hoping to run some tests this weekend on it and hope it doesn't fry.
Old 06-10-2014, 04:38 PM   #320 (permalink)
Have you been commuting with the Civic for the past week? How is it doing?
