08-21-2008, 01:18 PM
#11 (permalink)
Ron proved to me that he and his legal team do indeed have our backs. Here's a link to a video of an interview Ron did on MSNBC ... if you're curious about the SG or what Ron is like.
A gadget that saves gas - AOL Video
Another audio interview he did:
http://www.podtech.net/home/3665/scangauge
08-21-2008, 01:38 PM
#12 (permalink)
The way that the scangauge intefaces with the ecm it would be enormously unlikely that the scangauge is causing any problems along the line of a lean engine code. The problem is that without knowing what is causing the problem, they are groping for straws. I would pull the scangauge, completely and not install it until after they figure out the problem.
It sounds like scangauge is trying to do everything it can, to help. Obviously, hind sight, pull the scangauge and if they ask if a scanner has been plugged in, tell them yes, that is how I know the error code. Scangauge is doing the exact same thing as any other engine error code scanner, so if that voids your warranty, then everybody who ever uses any scanner is going to be voiding the warranty. Good luck with the car.
08-21-2008, 03:34 PM
#13 (permalink)
Pokémoderator
Markmysite -
They are lying. Linear-Logic rulezzzzzz!
CarloSW2
08-21-2008, 09:02 PM
#14 (permalink)
Hi-Tech Redneck
That code is obviously a vacuum leak and the mechanics cannot find it. Maybe you can find it yourself? Do a good visual and then start the car up until warm, spray parts cleaner/carb cleaner around the intake and vacuum hoses liberally and listen or "feel" for the engine RPM changing, then you pinpointed the vacuum leak.
I used to work at a dealer and it seems their inability to solve a simple problem and blame it on another product that has nothing to do with the PCM other than monitoring systems has created more problems than it solved.
Good luck my friend
GeoMetroforum.com - got mpg?
08-21-2008, 10:39 PM
#15 (permalink)
Steady as she goes
READ THIS!!...., I hope this helps..... Last year I had a VERY similar situation on an '06 vibe. Customer brings in their car with a "ck engine" light.. with the same lean code you have. After ALOT of time looking and I mean ALOT of time looking for the leak, This is what I found. On top of the transmission between the air cleaner box and the engine there is a solenoid with a vacuum lines running to it, It may even be bolted to a bracket that is bolted to the cylinder head or to the top of the trans. Right next to that or somewhere there about's is another hose coming from the air cleaner box that is also about the same size...about 5/16" or 3/8" . MAKE SURE that those hoses aren't backwards or mixed up some way/ some how. The best thing that I can say is, If you can find another Vibe and compare the hoses that come off of the air cleaner box and that solenoid and make sure your's are routed EXACTLY the same and going to the same ports. What it did on the one that I had was, The hoses were mixed up and it created a vacuum leak inside the air cleaner box. With the engine running I never heard a vacuum leak because the leak was inside the air cleaner box!!!...GOOD LUCK !!!
Not all dealerships are bad.....Only about 1% are good LOL
How about a 1 Litre Street rod?
08-21-2008, 11:01 PM
#16 (permalink)
Steady as she goes
Boy, You really have me thinking now. That was like two thousand cars ago  I'm not sure exactly what hose it was. But what I am sure of, Is that there is a hose that is about 5/16" that goes to the air cleaner box that can be easly mixed up with a ported vacuum hose that goes to that solenoid......If the air cleaner box assembly was removed at one time these hoses can be switched..... Man, now I'm not going to be able to sleep....
08-21-2008, 11:20 PM
#17 (permalink)
Good luck my friend
I think so too. I was reading some posts in other forums about using either starting fluid or carb cleaner to find the leak. The thing is it's a very small leak and barely affects engine idle. I wonder if I spray around if it would uptick the engine still? Probably would I bet since it would feed directly in and rev it a bit.
I hate that, like when you can't remember the name of a song or an actor but it's right on the tip of your tongue. Only when the person leaves do you actually remember it.
They are putting the new PCM in tomorrow. If that doesn't fix the CEL code (which I'm pretty sure it won't) I will go over there and try the spray trick and check those hoses on the air cleaner box. Maybe one is just even loose around there from when my oil was changed last and they looked at the filter.... wait a minute ... I bet that is it. I had my oil changed and they always check the air filter when you do that. I bet they knocked one of those hoses loose on the air box.
The plot thickens. Will post more tomorrow after I go to the dealer and check it out. Thanks for the tip... I think you might be onto something.
08-22-2008, 12:59 AM
#18 (permalink)
Steady as she goes
Good luck, I now remember that they had intake manifold leak issues too....  I also agree that the computer won't fix it.....
08-22-2008, 06:38 AM
#19 (permalink)
Hi-Tech Redneck
After you fix the problem yourself, you can get a job there as the new Service Manager
The Following User Says Thank You to Johnny Mullet For This Useful Post:
08-22-2008, 10:20 AM
#20 (permalink)
Originally Posted by Markmysite
Well, I called Linear-Logic (company who makes SG) as soon as they were open. I spoke with Ron DeLong (the inventor of the ScanGauge) for quite a while. ..... How freaking cool is this guy?!?!?!?!?
Ron's a smart cookie and is obviously concerned both about your personal situation and the potential harm that could be done to his business if dealerships get away with telling people that a ScanGauge could void a warranty. Imagine the potential impact on his bottom line of that rumour spreading unchallenged on the 'net.
I've also spoken to him at length, and he's the real deal.
