Old 10-22-2011, 11:04 AM   #361 (permalink)
PaulH
MPaulHolmes's Avatar
It's beautiful.
kits and boards
Old 10-29-2011, 07:34 AM   #362 (permalink)
jackbauer's Avatar
Its alive!!! Alive I say! Had two small problems. Seems my secondhand 3 phase bridge rectifer had a shorted diode. Fortunatly , I powered up with a light bulb in series with the mains supply (old habits die hard!) so no damage was done. Moral of that story : don't use cheap second hand parts. Next the display told me my mains bus was at -900vdc. I missed out two pins on the arduino and pcb. Once they were fitted it ran up no problem with 300w of light bulb load. Now running a 240v 2500w electric oven element as per the photos. I'll have some video and more photos later if it doesn't explode
ID:	9672   Click image for larger version
ID:	9673   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following 4 Users Say Thank You to jackbauer For This Useful Post:
LouMan (10-30-2011), MPaulHolmes (10-29-2011), mrbigh (10-29-2011), Nevyn (11-01-2011)
Old 10-29-2011, 01:04 PM   #363 (permalink)
PaulH
You are unstoppable. Don't you ever have to debug anything for more than 3 seconds?! Do you have any idea what the power factor is going to be?
kits and boards
Old 10-29-2011, 04:06 PM   #364 (permalink)
jackbauer's Avatar
Paul , i guess i'm just lucky! most thing never work first time for me Power factor won't be great on this version but i'm working on a boost pfc frontend that will bring it up near unity. I'm also considering running it on 3 phase where pf is not so much of a concern.
I took it up to about 3kw later on today then had a mishap! The battery sensing resistor got hot enough to burn through the insulation of the ground sense wire. Bang. And yes i got it on tape Took out the igbt , driver chip and dc dc converter. Vaporised the sense resistor. Got the bits swapped out and its now up and running again.
Here is some video from earlier tests :
I have to say I'm very impressed so far. No temp rise at all , very stable. I would like to identify the weird noise I observed on the scope in the video. Any ideas?
www.evbmw.com
Old 10-29-2011, 06:08 PM   #365 (permalink)
jackbauer's Avatar
The big bang
www.evbmw.com
Old 10-29-2011, 11:33 PM   #366 (permalink)
PaulH
That was awesome. There's something really fun about feeling like you almost died. Maybe fun's not the right word.
kits and boards
Old 10-31-2011, 05:18 AM   #367 (permalink)
jackbauer's Avatar
Seems my mistake was not mouting the sense resistor to the heatsink! doh
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
TheSGC (11-17-2011)
Old 11-07-2011, 04:11 PM   #368 (permalink)
jackbauer's Avatar
Quick update. Finally received a box of 2500w electric oven elements. Wired up two and powered up. The charger kinda looked at em and said "Whats this? an led?"
www.evbmw.com
Old 11-07-2011, 05:22 PM   #369 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
I can not even imagine the speed of your electric meter with those magawatters on testing.......
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 11-12-2011, 04:00 PM   #370 (permalink)
jackbauer's Avatar
Charging the bmw traction battery :
www.evbmw.com
The Following 2 Users Say Thank You to jackbauer For This Useful Post:
MPaulHolmes (11-12-2011), thingstodo (11-20-2011)
ev charger
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 07:00 AM
Open source PCB design dcb OpenGauge / MPGuino FE computer 39 04-25-2010 09:18 PM
Open Source electric conversion information bennelson Fossil Fuel Free 8 02-14-2009 11:23 AM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 03:10 AM
