Old 03-18-2009, 01:52 AM   #51 (permalink)
PaulH
MPaulHolmes's Avatar
I was reading about your questions on the EVTech list. You are doing an awesome job!!! This is very close to the way I was wanting to try it. I really appreciate you putting all that work into this! Down the road if you want to switch out the 555 timer for a micro-controller, I just bought 10 ATMega8's awhile ago, and I could help with the programming if you want. Awesome Job!
kits and boards
Old 03-18-2009, 02:04 AM   #52 (permalink)
PaulH
I did get voltage spikes and ringing on the rise and falls. They were pretty small, like 3-4 volts or so. The ringing didn't seem to increase in magnitude as the voltage increased if I remember right. I'm about to test the car's version in a couple days, so I'll double check that. One thing that helped with the spikes was putting small (like 0.1uF, 0.01uF, 1uF) MLCC capacitors from the input of the gate driver to ground.
I actually did it in real time just to see how it affected things. It was pretty cool. You could actually see the spike shrink each time I inserted a capacitor, and it would grow when I removed it.
Is the freewheel diode responding too slowly? What's the response time for it? I guess I could look it up. Never mind. hehe. I think you gave the part numbers. Hmm... Could you get away with just a single 150 uH inductor? Have you seen what it looks like with just one of them in the circuit? (are you using 2 of them? I forgot. I guess I can go back and read it in a second. hehe)
kits and boards
Old 03-18-2009, 02:05 AM   #53 (permalink)
Joe
I did some research about the high frequency ringing and determined that it was due to the parasitic inductance and capacitance in the wires/FET etc... The frequency is around 3.3 MHz, so I think this is reasonable.
Anyway, I also read about RCD snubbers and hacked one together out of components laying around. It's pretty ugly, so I didn't even take a picture of it. But it took care of the high frequency oscillations, but left the high voltage spike.
The first picture shows the new readout at low power, and the 2nd at high power. The high frequency oscillation is damped away, but the voltage spike remains.
The last photo is actually taken while charging a battery at 20 amps (I used the 12V SLA accessory battery from my EV as a guinea pig). The FET was starting to get warm, but still touchable, but I didn't let it go long since I didn't want to push it.
So, given that my purpose of this stage was to demo the basic power circuit by actually charging a battery, I'd say this is a success so far!
Things to do:
Determine if the voltage spike is a risk. Will it increase at higher input and pack voltages? Is it only dependent on current? I plan to do some tests at 120V, but have to get my hands on an isolation transformer in order to use the scope (I tried - apparently it doesn't like grounding the scope to a rectified rail).
Get some more input caps. At 20 amps, they were draining to zero quickly on each AC cycle. I don't think this is good, but I really don't know.
Then, further into the future, implement a microcontroller to fully automate charging...
ID:	2950   Click image for larger version
Old 03-18-2009, 02:15 AM   #54 (permalink)
Joe
I do plan to switch out the 555 timer at some point, and I have zero experience with micro-controllers. But, your success so far with the motor controller gives me hope! Were you able to learn just from the application notes? What materials would you recommend to help learn?
I'll have to try the small caps on the driver input - you're referring to the signal input, right?
As for the diode, it appears that the spike takes about 100 ns to build, but I couldn't find the forward-recovery time (is that right?) in the data sheet and I have no idea whether a typical diode can handle that. I haven't tried removing one of the two inductors, but that could at least verify the source of the spike.
Lotsa stuff to try! Will have to save it for another day...
Old 03-18-2009, 01:35 PM   #55 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Jyanof,
What range of voltages does your current charger setup allow for?
Lower voltage chargers are not that expensive, but above 72V is. An open source charger that could do 72-144V would be ideal.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 03-18-2009, 03:33 PM   #56 (permalink)
EcoModder Student
esoneson's Avatar
Me too, me too! I am also looking for a reliable high voltage 144 volt battery charge system. I love the idea of the open source solution. There are plenty of people who would love to have that option.
Paul let me know about the development system for the AtMegaXX microprocessors and I now have one on order. Complete setup including several processors for under $100. Develop code in Windows and load to the SDK board. Couldn't be easier. Software CAN be a viable solution.
Now I just need to learn more about hardware.
Eric
1995 BMW 318i EV in the making
Old 03-18-2009, 03:44 PM   #57 (permalink)
Joe
Originally Posted by bennelson View Post
Jyanof,
My current charger is a quickcharge model - 20A and set for 144V. I find it adequate as a stand-alone charger that sits in the garage. I think it lacks input flexibility (240 only), accurate charge termination (doesn't detect a minimum constant current at end of charge), and is outrageously bulky and heavy at 60 lbs and the size of a large over-stuffed backpack.
Obviously, I'm moving forward with the intent of being able to charge higher voltage packs like mine, but that doesn't mean the charger would be limited to such high voltage packs. It'd be easy to adjust the settings - either in software or externally with knobs - to allow the controller to sense different pack voltages. I think the only question would be if the system is stable enough at different pack voltages to allow the controller to maintain current control during bulk charge or voltage control during the constant voltage phase.
I suspect that 72-144V would be doable, but we'll see!
Old 03-18-2009, 05:38 PM   #58 (permalink)
PaulH
If you go with AVR, there's AVR Freaks
They are very helpful. I always had an answer to any question I had before the end of the day. I learned mostly how to do stuff from the data sheet. It was one horrible week.
Ya. In addition to the small capacitors, I also use two 4.7uF tantalum capacitors in parallel (which I guess are still small haha) connected from the signal input to the gate driver to ground. If you use electrolytic capacitors, they will get really really hot, in fact, any capacitor with too large of ESR, it will burn up (at least it did in my case).
The diodes I'm using have a reverse recovery time of 22ns and forward recovery time of 220ns. It's sort of weird. 220 ns seems like a long time, but I didn't have any problems with spikes. I'm switching at 16 khz.
What switching frequency are you using with the 555 timer? Higher switching frequency can prevent the capacitors from draining completely, and might allow you to use a smaller inductor for smooth current, but I think you can overcome the voltage spike with the right diode. It must be possible, dang it! haha!
kits and boards
Old 03-18-2009, 05:46 PM   #59 (permalink)
PaulH
Current control was a little tricky, but turned out not to be that bad. You just need a hall effect current sensor, and then a control loop to modify the PWM duty until you get the current that you want. That was the last 2 months of my life. I sort of wish I had it back. haha! just kidding. I think it would be the same idea for charging batteries, of course I have no idea what I'm talking about.
kits and boards
Old 04-09-2009, 01:33 AM   #60 (permalink)
2004 Prius Owner
lectruck's Avatar
Is there any update on the Chargers progress, now that Ben is trying out the Cougar Controller in could come in handy?
ev charger
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 07:00 AM
Open source PCB design dcb OpenGauge / MPGuino FE computer 39 04-25-2010 09:18 PM
Open Source electric conversion information bennelson Fossil Fuel Free 8 02-14-2009 11:23 AM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 03:10 AM
