Old 01-02-2011, 10:35 PM   #141 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Originally Posted by MPaulHolmes View Post
Ben, no one else even stood a chance.
Paul, your unwavering faith and confidence in my ability has made my day!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-02-2011, 10:38 PM   #142 (permalink)
Woohoo, congrats Ben! Nicely done.
Old 01-02-2011, 11:32 PM   #143 (permalink)
Building the future! :-)
Good for you Ben! Well deserved :-D
Old 01-03-2011, 03:32 AM   #144 (permalink)
jackbauer's Avatar
Well done indeed
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 01-05-2011, 01:51 AM   #145 (permalink)
He ain't gonna die!
The Rooster's Avatar
Tree Catcher - '94 Acura Integra LS
90 day: 32.12 mpg (US)
The Old Dog - '92 Honda Accord LX
90 day: 31.58 mpg (US)
That's an awesome car. How powerful of a generator do you think you would need to actually be able to drive the car directly?
Old 01-05-2011, 02:05 AM   #146 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
I think a 7k generator would do it.
My YouTube Videos
Old 01-05-2011, 01:27 PM   #147 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
OMFG!!! Ford Pinto effect on steroids. Fuel does not belong in a passenger compartment. Please consider a roof rack. Also cars have engines behind firewalls for a reason ( and its not just to protect against fire).
Old 01-24-2011, 10:36 AM   #148 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Yea!
Just won another contest with the same project!
Ok, not nearly as big, just a runner up.....
Still, I get a T-Shirt! Yea! Can never have enough t-shirts with logos on them!
Also, the prize includes a $50 gift certificate at Personal Factory (tm) - design, make & build your own custom products
What should I do with that? Make clean transportation related keychains? Laser cut the Open ReVolt logo into the controller cover!?!?
What ideas do you have!?
My YouTube Videos
Old 01-24-2011, 10:38 AM   #149 (permalink)
Lets start a home built hybrid club :-D
Old 07-03-2011, 05:31 PM   #150 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
This project hasn't been at the top of my list lately.
I sort of didn't do anything more on it since that contest, but being up at the MREA fair a couple weeks ago, I was throwing around a few ideas with other people.
The main problem is that there's a 15 amp outlet on this generator, yet it has a 30 AMP main output. That means that I am only getting half of what I potentially could out of it!
I looked on the web and found that 30 amp bridge rectifiers (to change AC output to DC) are cheap - like $10 or so!
Running 115v AC out to DC should give me somewhere in the neighborhood of 160V DC! That's MORE than enough voltage to charge my battery pack! In fact, I would have to figure out how to LOWER that voltage. (How about a 30 amp Open Revolt with the throttle PWM set so that my battery pack "sees" an appropriate voltage? That way it would be adjustable in case I change the number of batteries)
Hmmm.... Wait, how's the math work?
AC volts times 1.41 (bridge rectifiction) = DC volts, right?
115v AC x 1.41 = 162.15VDC (minus, what, a volt? for the bridge rectifier?) Call it 160VDC. 160V / 12 batteries = 13.33V per battery.
Could it be that simple? Run a generator through a bridge rectifier to a 144V battery pack for a simple hybrid?
Not sure how many amps I would pull while crusing at 144V, but I only need the AVERAGE to be 30 amps to be able to drive indefinately on the LP generator!?
I was also talking to an electronics friend. He said that the generator has an internal sensor that regulates the output voltage. If I was able to change that, I could send something OTHER than 115V AC out of the generator.
I think somebody mentioned doing something like that a while back, but I really didn't want to mess with the generator, and STILL don't know much about electronics.
I'm sort of liking the idea of a 144V Hybrid car though...
My YouTube Videos
"The Volt" May BE SCRAPPED!- NEVER BUILT!! Jammer Hybrids 460 08-22-2013 07:08 PM
DIY hybrid (detailed noodling of crankshaft-mated electric assist method) NiHaoMike Hybrids 16 03-03-2012 05:41 PM
Volt may become a parallel hybrid RobertSmalls Hybrids 43 10-10-2010 07:14 PM
--- 48 volt golf cart motor --- for diy hybrid possible? basslover911 Hybrids 19 07-06-2010 06:46 AM
News: GM planning dedicated high efficiency hybrid (in addition to the Volt) MetroMPG Hybrids 17 07-16-2009 10:20 PM
