Old 02-12-2011, 11:10 PM   #1 (permalink)
Grand Prix - '02 Pontiac Grand Prix GP
90 day: 24.01 mpg (US)
My First Mod! (Lower Grille Block)
Using the material linked here, I did my first mod today.
Notice the gaping holes along the bottom:
Here's the fiberglass panel, curved to show the edge thickness (.090"):
Tools enlisted:
I planned on just having one sheet across the whole thing, but the curvature across multiple axes made getting it lined up difficult. I ended up cutting the original panel in half at the middle:
Here's what I mean about the curves. Front-to-back and top-to-bottom:
I've got some black paint to make it look decent; that will have to wait for another day. Like others have done, I used cardboard to make a template. Once I had one side done, I used it as the template for the other side.
I used wood screws to fasten it at three locations per side (top and bottom at the middle and bottom on the outside. I drilled holes first to prevent any cracking and to help with alignment. Took about 2.5 hours with my 2 year old son 'helping' me
Thanks to everyone here for your inspiration and tips.
Old 02-13-2011, 03:25 AM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
nice job!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 02-13-2011, 08:11 AM   #3 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Time well spent. Future ecomodder?
And nice work. On my 06 I blocked the uppers. No testing yet.
Old 02-13-2011, 12:29 PM   #4 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
Good start, i would suggest getting some plexiglass or lexan and using it to cover the fog lights, it would help smooth the flow around the front corners
Old 02-13-2011, 02:34 PM   #5 (permalink)
Yeah I'd like to do that soon; I've looked at it a couple times but can't think of a good way to connect the lexan. I want it to be flush with the surrounding panel and that makes it trickier. Any suggestions?
Old 02-13-2011, 03:40 PM   #6 (permalink)
it would be pretty hard to get it flush with the rest of the panel imho, but i would think that using 4 small machine screws probably wouldn't hurt anything
Old 02-16-2011, 12:16 PM   #7 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
I never did a lower grill block on my GP but I did do an upper block by taking thin plexy and cutting it a bit larger than the upper grill then drilled holes and placed the plexy between the grill and bumper.
Fog lights would be hard and the only way I could think to do it is to make a template that will match the hole. Then when you make the plexy cover from the template add three tabs in a Y shape. Cut slots in the bumper that match the tabs and then insert the block starting at the bottom. It will be a little tough to get in but should work.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 02-17-2011, 05:03 PM   #8 (permalink)
Phantom, did you notice a change by doing the upper? I'm seeing higher temps with all of the lower blocked; I'd like to stay away from running the radiator fans if possible. Did you put the upper block on the outside or engine side of the black honeycomb? I would think that outer would help FE more but behind would look closer to stock...
For the fog lights, I think I'll try making a cardboard template and then making the plexiglass cover by tracing the template. Running three wood screws at the edges should hold it in place.
Old 02-17-2011, 08:03 PM   #9 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Post some more pics of how it looks now from the front!
Coast long and prosper.
Old 02-20-2011, 02:30 PM   #10 (permalink)
Here's a shot after I painted the panels black. I only put the right one back on because I think my engine temp was getting hot enough to trigger the radiator fans. Does anyone know what temp will trigger the fans? I know I'm up above the thermostat trigger temp...
Now I just need to paint the three screws!
