Old 06-07-2014, 04:09 AM   #1 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Do manuals coast farther then automatics?
I have been thinking about this the past few days, and I figure I would just ask. Do manuals coast farther than automatics? Both in neutral. Lets say you drive the automatic and manual on the same exact piece of land, at the same speed put both cars in neutral, which one will coast farther?
Old 06-07-2014, 10:36 AM   #2 (permalink)
...beats walking...
Which, IN or OUT of gear(s)?
Manuals have LESS overall power loss (~12-15%) AND can be placed in NEUTRAL, but some gears are always engaged.
Automatics have MORE overall power loss (~15-20%) BUT are never completely disengaged due to combination of pump and torque converter operations.
Old 06-07-2014, 11:29 AM   #3 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
In theory, the automatic will. Automatics weigh more, and all things being equal, adding weight adds momentum. Imagining like you said, both in neutral at the same speed in the same spot with same conditions, adding weight will increase the coast distance. Granted it's not too much weight, standards have weighed less in every vehicle I have compared the two transmissions.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 06-07-2014, 12:05 PM   #4 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
Being about 100lbs heavier then standards hauling that heavy automatic transmission costs you fuel just in its shear weight let alone its friction losses.
Most of the wasted fuel caused by the automatic trans is due to the lack of early/lower rpm high gear engagement, I suspect you could due very well with a gear selectable automatic trans.
Save gas
Old 06-07-2014, 12:16 PM   #5 (permalink)
Hydrogen > EV
An automatic will win in this regard- it should coast further, all other things being equal.
Best Tanks:
Old 06-07-2014, 12:19 PM   #6 (permalink)
ecomodded's Avatar
2 feet further ? 10 feet further ? might friction losses cancel it out ?
Save gas
Old 06-07-2014, 12:26 PM   #7 (permalink)
Hydrogen > EV
What friction occurs when it's not in gear? I didn't think there was any.
Best Tanks:
Old 06-07-2014, 12:27 PM   #8 (permalink)
ecomodded's Avatar
input shaft is still spinning
But perhaps that's not a real good argument as the standards transmission is as well , only with lighter fluid viscosity
Save gas
Old 06-07-2014, 12:51 PM   #9 (permalink)
Hydrogen > EV
I am not aware of the differences between the standard and auto, I was only aware of the weight difference. I couldn't speak to the input shaft, but I imagine if both have then it would be working the same.
Best Tanks:
Old 06-07-2014, 02:25 PM   #10 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Where does the auto trans fluid pump get its power? Is it a parasitic load on the trans directly, indirectly via the engine, or more indirectly via some electrical system drawing on the battery?
