Old 05-13-2012, 11:41 PM   #11 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
11 is about what my dad got out of his 99 w/ 5.9l, i could only get 16mpg burning a whole tank on a trip running about 60mph the whole time. from the rest of your comments i'm thinking look at the "100+ hypermiling tips" and maybe a scangauge, if you could get .5 mpg more with its help it would pay for itself in about 10,000miles since youre looking at 11mpg
my dad went from 11 to 16, driving the same way, the same routes, but with an '08 5.3L silverado
Old 05-13-2012, 11:47 PM   #12 (permalink)
Iv read them and was using them and still getting ten mpg and mopar or no car
Old 05-14-2012, 12:04 AM   #13 (permalink)
But I also don't have current data after the sensor change and disconnecting the evap
Old 05-14-2012, 12:14 AM   #14 (permalink)
Team Saturn
if the evap system is working properly it should be helping your mileage a little, and the electric fan(s) and grill block should help. i wouldnt think the cold air would help, but i hate how the stock air intake attaches to the tb worse, so i'd keep it anyway.
Old 05-14-2012, 12:30 AM   #15 (permalink)
Weird Thing - '00 Holden (GM) Commodore SS Series II
90 day: 18.67 mpg (US)
Does the chip run a lean cruise map? You won't get away with what a car can due to weight and drag, but you might still have some fat in your cruise mixture.
You could also pick up 1mpg by friction reduction treatment to engine and drivetrain - something like Militec-1 or Slick 50. Some oils help mpg too but careful not to go too thin.
I agree with you about cold air. Hot fuel is good for mpg though, but loses power in some cases - not always.
Old 05-14-2012, 01:51 AM   #16 (permalink)
My thought in the evap IDs there's like4000 miles out crap drawing vacume he'll I'm pulling 20 inches at idel warmed up usually out pulls 15 to 18
Old 05-14-2012, 02:38 PM   #17 (permalink)
Family Hauler - '06 GMC Yukon XL 1500
Fun Commuter - '97 Saab 900 SE 2.0 Turbo
Skid plates for aerodynamic improvement under the truck?
There's a guy on here (forgetting the name currently) that was using skid-plates - both aftermarket, and some home-made out of thin aluminum sheets, to improve the aerodynamic drag under his Cherokee, could help with the Ram as well... It won't be huge, and probably not as big as an aero-cap for the bed, but could gain you a little if you want to go through the time/effort.
If you make a type of belly pan following the lines a skid-plate would, you'd improve airflow without really cutting into your approach angle, etc. Not as effective as dropping it, but it would help while keeping it a truck. Looking at doing something similar to my Suburban when I get the chance... but I'm a new lurker here, too.
Old 05-15-2012, 10:35 AM   #18 (permalink)
Any thing else
Old 05-15-2012, 11:33 AM   #19 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
55 mph. Easy acceleration, drive with load, light anticipation...like someone mentioned previously "100 tips" should help where there biggest gains are to be had...driver skills.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 05-15-2012, 11:38 AM   #20 (permalink)
I'm doing all of that neutral and easy driving I'm not going to turn three engine off tho because it's a auto what about h2o
dodge truck help mpg
