Old 08-23-2016, 02:04 PM   #1 (permalink)
The Blazer - '01 Chevy Blazer LS
The Impretzel - '93 Subaru Impreza L
90 day: 38.62 mpg (US)
94 Civic Worth a new motor?
I have a 1994 Honda Civic DX Hatchback sitting in my yard with a blown head. It has no rust and a good automagic transmission. As far as ecomodding platforms go would it be worth it to invest time and money into putting a new or mechanically sound junkyard engine into this car?
Old 08-23-2016, 06:53 PM   #2 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Of course it's worth it! 90s Civics are awesome!
EcoModder Fleet list - EcoModder.com
I'd convert it to a manual too.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 08-23-2016, 09:08 PM   #3 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Yes! Search Car-Part.com--Used Auto Parts Market for a replacement engine.
But if you are going to replace the engine, which all by itself is good enough, why not go for a much newer engine? Get a manual Honda Fit 2007 engine and ECU! You would need to fabricate engine mounts and a shifter for the manual. But you'd get a 1.5L with ivtec and greater efficiency.
james
Old 08-24-2016, 01:19 AM   #4 (permalink)
I am as eager as anyone else for you to undertake a huge project! Update frequently!
Old 08-24-2016, 11:12 AM   #5 (permalink)
I am currently in search of a motor and manual transmission that will be a direct fit to the factory Dx mounts. Does anyone on this site have any information on what will/ wont work. Was considering a V-tec but finding and wiring a V-tec Ecu to the Dx harness might be difficult.
Old 08-24-2016, 12:25 PM   #6 (permalink)
Cyborg ECU
You would need to adapt the harness to accommodate the VX hardware, such as its O2 sensor. Even then, your shorter gearing on your DX would complicate for accomplishing the lean burn that is the holy grail of VX/HX trims for ecomodders. It could turn out to feel like a pretty big PITA, especially if you were looking for an easy bolt on.
The 1992-1995 DX, LX, AND Del Sol (not the Si Del Sol) all had D15B7 engines. And the CX had the D15B8. But a CX sourced D15B8 and ECU shouldn't require much or any mods to the harness, and it might have a fuel map that is tuned to sip fuel better than your DX engine originally was. Maybe.
EDIT: I think I have the 1992-1995 Civic factory service manual in PDF form on my computer (I am on my mobile right now). If you need it, PM me an email address and I will send it to you.
Old 09-18-2016, 06:55 PM   #7 (permalink)
Yeah, so many of Honda's other motors would be compatible that it's definitely worth putting a newer one in there.
