Old 11-05-2008, 03:20 PM   #1 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
The Dreaded P0420 Code
The Teg threw a random code while driving today -- P0420 (unexpected oxy sensor readings, bad cat, etc.)
It hasn't popped back up, but I'm starting to worry if the cat is going bad. Not a cheap fix... 140K miles -- is this a reasonable amount of time (what's the average?) Could be a sensor...
Hopefully it was an EOC fluke (crosses fingers).
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 11-05-2008, 03:26 PM   #2 (permalink)
O2 sensors are easy to replace and a cat isn't too hard to replace either.
OBD-II Trouble Code: P0420 Catalyst System Efficiency Below Threshold (Bank 1)
Old 11-05-2008, 04:08 PM   #3 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
That's a great site -- they cover some obscure codes that saved me in the past.
I couldn't consciously run it with a bad cat or sensors, so I'd have to fix it should it become a continuous problem. The goal of retaining the car is a combination of environmental and economical reasons, so those two factors sometimes don't agree.
Nevertheless, it would be a great time to replace the whole rattling exhaust system.
We'll see if the code returns...
-Rick
_
_
Old 11-05-2008, 04:49 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Hopefully it's just a fluke. Crazy computers
Old 11-05-2008, 05:08 PM   #5 (permalink)
Red
Red's Avatar
I'm in the same boat with the Insight. Don't bother with any of the tricks on torching the rear O2 to see if its bad just replace it.
It is said that cats don't go bad, but just get caked up with sulfur. One trick I heard about but haven't tried yet is to pull the cat, dunk it in a lemon juice solution and bake it for a good 6-8hours
Old 11-05-2008, 06:30 PM   #6 (permalink)
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
i have had that code for years, no emissions testing = no cat
Old 11-05-2008, 09:12 PM   #7 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
If the exhaust rattles, the cat melted down and is throwing the code since it's not cleaning the exhaust like it's designed to. I removed my cat for performance reasons and simply tied my 02 sensor (downstream) to the frame and it keeps the light out.
GeoMetroforum.com - got mpg?
Old 11-06-2008, 01:03 AM   #8 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
The major rattle/buzz is coming from an inner-tube style A-pipe that busted loose years ago (very common Honda flaw). I pulled the heat shields as well -- all they did was rattle.
Something else further back is rattling -- likely the muffler. The 3rd random clanking occurs at low RPM idle -- the source can't be ID'd. It's a loud metal-to-metal clank/squeak.
I used a data logger to check the pre- and post-cat O2 sensors and compared the output to an expected voltage chart (about a year ago). It all was well, yet the rattles haven't changed.
What's the average service life on the converters? The car won't pass inspection without one (which is coming up -- plus I wouldn't feel comfortable with the emissions factor)...
-Rick
_
_
Old 11-06-2008, 02:15 AM   #9 (permalink)
DMC - '99 Honda Civic DX
I've been told the cat life is about 100k. My exaust was making a weird noise and I went to the shop. They told me I had a crack in my manifold just from the test drive. They came back, took off the shield and showed me a huge crack with exaust coming out of my manifold. A new sound started a couple of months later and they narrowed it down to a heat shield. They told me just keep it there and don't worry about it.
Old 11-13-2008, 09:17 PM   #10 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 38.06 mpg (US)
If you have an angle grinder and are pretty handy you can replace the cat yourself, most parts stores will have a direct fit replacement unit available. I changed one on my mom's Camry. Exhaust work basically involves grinding off some rusted bolts and slapping the new piece in. Usually.
HELP! Check engine light - Loss of power bennelson Off-Topic Tech 28 07-07-2009 06:13 PM
Anyone know anything about MA emissions laws? SVOboy The Lounge 8 10-19-2008 03:03 PM
Help w/ mpguino space shuttle code please forgottenmindset OpenGauge / MPGuino FE computer 14 09-07-2008 03:17 PM
CA Vehicle Code - Mirrors thebrad Aerodynamics 2 08-30-2008 11:03 PM
Perhaps honda specific: Will a code 41 (o2 sensor heater) tank my mileage? SVOboy Off-Topic Tech 13 08-04-2008 09:35 PM
