Old 09-04-2012, 06:43 PM   #1 (permalink)
Opposite of white lightning - '98 Ford F150 Ext cab lariat
90 day: 16.94 mpg (US)
Tires/Gear Ratio/MPG
Hey y'all I've got a confusing (to me anyway) question. I'm looking to downsize my tires from 275/60/17 to probably 255/60/17. I figure this will effectively up my gear ratio from 3.55 to around 3.73ish. I know my lower gears are better for mpg and I love that, but I'd like to be able to tow better and with having 3.73 gears I would probably have better mpg while towing anyway. Now with smaller tires shouldn't I have less energy to rotate the tires effectively upping my mpg?
Please help me figure this out. I obviously don't want to change my gears as in mechanically swapping them and since I need new tires anyway, I just thought I could kill two birds with one stone.
thanks,
DC
1999 Chevy Tahoe
2wd 3.42 gears
Old 09-04-2012, 06:47 PM   #2 (permalink)
royanddoreen's Avatar
z - '03 nissan 350z touring
90 day: 36.21 mpg (US)
Diniro - '18 Kia Niro Ex
90 day: 47.99 mpg (US)
whats you're rpm at cruising speed now?
Old 09-04-2012, 06:52 PM   #3 (permalink)
@ 70mph I'm just above 2000rpm. like maybe 2050 lol
1999 Chevy Tahoe
2wd 3.42 gears
Old 09-05-2012, 10:33 AM   #4 (permalink)
Tire Geek
CapriRacer's Avatar
thanks,
DC
I think you have that backwards. LARGER tires would reduce the effective ratio.
Think of it this way, a smaller diameter traveling at the same rpm generates a lower speed.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
Old 09-05-2012, 11:08 AM   #5 (permalink)
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
No he has it right, a higher number in the gear ratio = a higher engine speed vs road speed, smaller tires = higher gear ratio = higher engine speed vs road speed
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
Old 09-05-2012, 12:04 PM   #6 (permalink)
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
Shows your only changing the Width of the tire and not the Diameter. For towing capacity and safety, youd be better off keeping the stock width, of 275/ and just changing the Sidewall Hieght(changing ratio) /55R17 or /50R17. If thats what your are trying to get at?
Refer to Post #7 by MetroMPG
http://ecomodder.com/forum/showthrea...tml#post324301
Helpful RR chart on the second link, talks more about width of the tire.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 09-05-2012, 12:13 PM   #7 (permalink)
You never want smaller tires on a tow vehicle.
You will be giving up a lot of weight capacity.
I see these are metric tires, unless they are LT truck tires you will need to derate their load capacity by 9% I think it is (I dont know why but the tire manufactures recomend this when putting a car tire on a truck or SUV, so do it).
The only reason you would ever want to consider a smaller tire when towing is if you were having trouble pulling the load.
Other than that bigger is better.
Taller Tires - EcoModder
Old 09-05-2012, 02:40 PM   #8 (permalink)
Tire Geek
CapriRacer's Avatar
Opps! I got confusiated.
Originally Posted by RiderofBikes View Post
Shows your only changing the Width of the tire and not the Diameter........
No, the diameter changes as well.
......... For towing capacity and safety, you'd be better off keeping the stock width, of 275/ and just changing the Sidewall Hieght(changing ratio) /55R17 or /50R17. If thats what your are trying to get at?........
That would also change the diameter - but as is pointed out, this also reduces the load carrying capacity of the tire which is a terrible idea. Think Ford/Firestone and that's what we are talking about.
CapriRacer
Old 09-05-2012, 06:59 PM   #9 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
the both have the same diameter according to tirerack.com 30" (275) 30.1 (255)
As someone else mentioned you have to change the second number
here ia tirerack chart for a tire that has both sizes
http://ecomodder.com/forum/showthrea...mpg-23182.html
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 09-05-2012, 08:01 PM   #10 (permalink)
275/60/17's are 31.1" vs 255's 30". This should give you a 2115 rpm at 70.This is not a lot of difference but the load range goes down 50-70lbs on 2100 lbs per tire. Nothing to worry about unless you are going to use max loads in your truck.My guess is you will lose some mpg which could be restored by driving 65 mph.Hope this makes sense? Roy B
