Old 05-12-2010, 08:23 PM   #41 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
BUMP the magic dragon........
if Superchow is st6ill around, maybe he could enlighten us as to what he means by lackluster performance during the summer? It may simply be because he is using the AC which is sucking out the available HP and he hasn't considered that yet.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 08-01-2011, 10:12 AM   #42 (permalink)
I know this is an old post but I could see dry ice used in performance engines for 1/4 mile drags. For a car with a turbo, you could pack the dry ice around the inter-cooler to help condense the air more (don't put the ice inside the intake). The only thing I'm not sure of is how much it would help. I do know that the performance gain would be more than the added weight if it is done right. You might also need to instal some sort of a drain for condensation build up inside the inter-cooler.
Subaru Outback Hot Air Intake Results brucey EcoModding Central 22 12-10-2008 07:41 PM
on a jeep 4.0 the intake manifold gets as hot as header they are so close, shield it 95CHERJUST EcoModding Central 5 10-16-2008 04:00 PM
Hot Air intake vs. Cold Air... why or why not? Blister General Efficiency Discussion 3 10-09-2008 10:01 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
Trying out an aftermarket Intake on a VX TomO EcoModding Central 0 11-14-2007 03:41 PM
