Old 12-22-2008, 08:10 PM   #31 (permalink)
Hello,
The very front of the car (the grill and bumper) is a high pressure zone, and it deflects much of the air flow up and over much of the hood; making the hood a low(er) pressure zone than the front. On my xA, which has the hood sloped down, this is still the case. The upper half of the windshield is also high pressure; but the base of the windshield is a low(er) pressure zone, as well.
The reason I know this the case on my car anyway, is when there is loose (light and fluffy) snow around the windshield wipers, it stays put; unless there is a gust of wind from the side.
In any case, the back of the hood/base of the windshield is a lower pressure zone than under the car. There are other threads that quote aerodynamic reference books showing that intake down low on the front and the exhaust on the back of the hood is the most efficient way to move air through a front radiator.
Old 12-23-2008, 02:21 AM   #32 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
autospeed had a great article on bonnet vents.
however i'm inclined to think from their results and from the placements of functional vents on production cars half way the hood is a better place the pressure difference with the front is much greater there than just ahead of the windshield. the back of the windshield is generally the place where the interior cooling air INTAKES are.
perhaps raising the hood at the back might still work because of the sheer size of the resulting gap, but relative small extractors early on the hood can do the same thing
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 12-23-2008, 09:44 AM   #33 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
If I had time, money, and a workspace I'd be working on a way to duct my rad. I mean, look at all this space:
If I could move the top supports out towards the front, I could angle it nicely to duct it out to the hood. Forget money, I just need time and a workspace. *sigh*
Old 12-23-2008, 12:58 PM   #34 (permalink)
Coroplast would make some nice ducting material, applied with duct tape.
Old 12-23-2008, 03:09 PM   #35 (permalink)
Ex-lurker
badum bum
Old 12-24-2008, 02:10 AM   #36 (permalink)
is that a concrete undertray? seems like any sort of ducting might include or double as one too
Old 09-10-2013, 05:31 PM   #37 (permalink)
The Truck - '02 Nissan GU Patrol ST
Another article on Radiator ducts, is about aeroplanes, but principles are the same, thought it best to tag on this thread:
Contrails ! Radiator aerodynamics
Regarding adjustment of mass flow, thought this comment was relevant:
In theory, it should be necessary to alter the intake opening at the same time as the exit.
In practice, it has been shown that once the intake cross section is 30 to 50% of the radiator block frontal area, the volume flow depends only on the exit area.
Hence the regulation by control of the exit area by means of cowl flaps, preserving the static pressure at the front face of the radiator.
Old 09-10-2013, 05:43 PM   #38 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
probably see a 10% improvement from concrete to maybe,.........oh I don't know..........
2x4s.........
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 09-10-2013, 05:44 PM   #39 (permalink)
mcrews's Avatar
sorry..........
ECO MODS PERFORMED:
First: ScangaugeII
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 10:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
